Question about SanDisk Sansa E280 MP3 Player
♥Puhlessz! Hey How'd You Take Off The 'Refresh Database' thing,cause mine wont load>.
  • 8,596 Answers
You will have to reset and upgrade the firmware, b/c you're
DB has become corrupted:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 05, 2008
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 10, 2008 | SanDisk Sansa e270 MP3 Player
Hang on refresh database
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Jan 19, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh database
Sansa
Dec 25, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh Database
I have the same problem and can not figure it out!!! how do I refresh database??!!!grrrrrr
Need help as well.
Thanks
Dec 12, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
"Refresh Database"
Nov 15, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Database refresh on Iriver H10
I have done this. my iriver is almost full i have the 20gb, when the you do the database refresh, it just takes a really long time. mine takes about 2 hours to finish, once you see the clock on database refresh you cant do anything but wait till its finished.
Oct 18, 2007 | iRiver H10 MP3 Player
Refresh Database Froze!
Hey duse. I managed to fix my problem. Go to this site and folow the instructions. http://www.anythingbutipod.com/forum/showthread.php?t=11233
Jul 24, 2007 | SanDisk Sansa e250 MP3 Player
Continous refresh database
I've got the same problem too. I read this on another website: 'well firstly drain the battery and then connect it to charge it up a bit. once it has been there for 5min or so take it off and then turn it on>settings>USB Mode>MSC once you have done that connect it up and it should work/recognise the player. i don''t know how this thingy happens but this is just how i fixed mine!' I'm gonna try it now on mine, and see if it works. I've just got to wait now... Good luck with yours.
Apr 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
