Question about Tech Solution TS-4500 Shredder
Tech soulutions tm paper sherdder
S/n2027667 05/06/02
what makes the red light come on
    New Friend:
  • 161 Answers
ELECTRIC !!
Posted on Jul 03, 2008
Two lights blinking red in epson t60, the ink and paper button
Paper remove button and ink remove are not working properly
Jul 24, 2012 | Epson TM-T60 Printer
Tip
Printer : Checking the printer
Check the lights on the printer
Power in solid green - printer is in ready mode, else:
  • disconnect and try another power source or power-adapter.
Paper Feed in solid red - no paper:
  • make sure paper is of the correct type and dimension. re-seat the paper.
Error in solid or flashing - hardware problem:
  • turn off the printer.
  • open and access the DIP switches, make note of the current settings, then set it all to zero.
  • remove the Connect-It module at the back and re-install it.
To test the printer do the following:
1. Disconnect the printer from the computer.
2. Turn the printer off. Make sure that there is paper and properly loaded.
3. Press and hold the Paper Feed button while turning the printer back on.
4. A self-test print-out that contains information such as firmware version and settings depending on the detected connection type.
on Oct 14, 2008 | Epson TM-T88III Thermal Printer
How do i turn on cutter
turn off and turn on again light goes off and it prints and stop without cutting the paper...TM 220a and TM 220b should come with auto cutters You have to unscrew the metal tab under the printer, ...
Jun 24, 2011 | Epson TM-U220 Matrix Printer
Turn the printer off and delete all print jobs. Open the printer cover and remove any paper from inside the printer and turn the printer back on. two red light segnul and not print .
Oct 06, 2010 | Epson TM-T60 Printer
RE: Epson TM-U200 printer with error (2 Flashes)
http://www.icscale.com/TECH%20MANUALS/TMU220_TRG_RevD.pdf
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
May 09, 2008 | Epson TM-U220 Matrix Printer
Error light on a Tm-H6000II
Whats the pattern of the blinking light? can you pls describe...
what type of interface are you using, USB, SERIAL, PARALLEL, ETHERNET?
Apr 30, 2008 | Epson TM-H60000II Thermal Printer
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Tech Solution TS-4500 Shredder Logo
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
