Question about Canon PowerShot S3 IS Digital Camera
How to take out internal battery?
Did you get a chance to write that how to fix manual for the memory card error for Canon S3 IS? Mines just starting giving me this error and I read that you can open the camera and take out the internal battery and it shoud work. Anything helps!!
THANKS!
Mata Fuala'au
The internal battery is located under the cover for the AA batteries compartment.  The internal battery holder is located next to the middle battery of the line of three batteries.  The end of the holder has the internal battery size printed on it (CR 1220).
Posted on Aug 01, 2008
The memory card does not stay inserted into it's slot and the camera shoes a memory card error.
Hi, I'm going to give you a link to a basic user guide.
http://www.google.ca/#hl=en&source=hp&biw=1224&bih=834&q=canon+powershot+s3+is+pdf+manual&aq=0v&aqi=g-v1&aql=&oq=Canon+PowerShot+S3+IS+PDF+Manual&gs_rfai=&fp=6a0673dc5c3f3912
It's a small PDF file which has a diagram on the correct orientation of the SD card and batteries I think the actual owners manual is lacking in these diagrams.
I think though that you are attempting to install the memory card the incorrect way.
Also I'm going to include a great diagram for the SD card locking switch that if in the wrong position won't allow your to format a new card to the camera.
Diagram
This should solve your problem don't forget to format your card to teh camera before using.
Jan 11, 2011 | Canon PowerShot S3 IS Digital Camera
Memory card error canon powershot S3 IS
Sounds like the camera may need to be sent into canon to be fixed. I had to do that once- they allow you to track the camera from the moment they receive it- till the moment it is fixed. It was not so bad.
Aug 12, 2009 | Canon PowerShot S3 IS Digital Camera
I have a canon power shot s3is and when i put a sd card into it it says memory card error. i've tried a number of other sd cards it seems not to read any card. just randomly started.
It is likely that an internal metal contact (one or several ones) inside the sdcard reader are bent, or damaged.
You will need to have your camera reviewed by a qualified technician to have it repaired, since it requires open the camera and evaluate the sd card reader mechanism.
Best regards,
Jul 11, 2009 | Canon PowerShot S3 IS Digital Camera
S400 memory card error. Turn on camera - display "NO IMAGE MEMORY CARD ERROR". Can not take pictures, can not display pictures. Have several memory cards - same message, different cards. If the camera...
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Feb 21, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
When I insert a memory card, all of a sudden I get "999" as the number of pictures available in stead of the accurate number. I have a G& and have never had problems before.
It may be fault with your memory card .
There is a chance that your memory card might have been corrupted
Also ensure that your battery is properly charged
There is also chance of mechanical problem existing in your camera .
Is your camera canon s3 or s5 or some other model
Sep 06, 2008 | Canon Cameras
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
Memory card error
On the old Powershot S400, this error was caused by a dead internal "clock" button battery. Fixing it required simply replacing the battery. But before you attempt to do that, would first suggest trying a different memory card.
Jan 20, 2008 | Canon PowerShot A540 Digital Camera
Memory Card Errors with Canon PowerShot S3
There most definitely is a solution to this problem. Follow this link for a step by step fix for the memory card error. It requires taking the camera apart but if the warranty is expired you have nothing to lose. Fix worked fine for me.
http://willj.net/2006/02/12/fixing-the-memory-card-error-on-the-canon-ixus-400s3/
Nov 22, 2007 | Canon PowerShot S3 IS Digital Camera
Memory card error
Try a smaller memory card size . I was trying to install a 4gb card and the guy at Kmart told me to try a 1gb card and that fixed the locked card error . No where in the instruction book did it address this problem.
Sep 24, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
782 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
