Question about Mitsubishi WS-65513 65" Rear Projection HDTV
I loose picture on my big screen
When I turn on the TV it will work for 30 seconds, then the picture will shut off. The screen is still on, and black. Give it 2 more seconds the screen turns blue and says cable in the top left corner. Turn the unit off, wait ten seconds, turn it on and the pictures comes back and the whole process starts over. Once and a while after the screen turns blue I would have to reset the system to get the picture to return, but lately there is nothing I can do to keep the picture on.
  • 2 more comments
  • fidel509 Jul 18, 2008
    mine also does the same but will just turn into alot of fuzzy lines like i was staring at static..... can you please help...
  • Anonymous Aug 12, 2008
    My tv is shutting itself off after an hour or two of operating. The green power light is still on when the screen goes blank. I have waited a few minutes once after the shut down and dark static lines will become visible. But mostly I shut the tv off with the remote and power back on and it comes right back on. Then it will shut down again after 20 to 30 minutes. This would appear to be a thermal problem. I pulled the tv away from the wall and pointed a fan to the rear. This did not help.
  • Jas0n22 Aug 12, 2008
    TV shuts off after an hour or two of operation. Green power light is still on. Left TV on for a few minutes and dark static lines formed. Mostly i turn the power off with the remote and power back on. TV comes back on and works fine for 20 to 30 minutes and then shuts down again. Appears to be a thermal problem. I moved the TV away from the wall and pointed a fan at the back of the TV. Same problems.
  • Josh Crager
    Josh Crager May 11, 2010
    me too, no ideas?
  • 233 Answers
Bad voltage regulator - BA09FP requires a bit of tech experience to replace, but its relatively easy. It took me about 1 hour to replace mine. If you need clarification on this, email me at Doin12volt at yahoo
Posted on Oct 09, 2008
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
Dec 20, 2015 | LG Televison & Video
TV won't respond to remote or button on the TV
Make sure you are running the Keygen as administrator
Jan 28, 2014 | Toshiba 55UL610U 3D TV
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
Magnavox big screen problem
Its not the bulb.
When it comes on is it real bright?
Did you loose the audio also?
Any other symptoms prior to having this problem?
Aug 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
May 04, 2017 | RCA 36V430T 36" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
