Washing Machines Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sometimes the washer randomly beeps continuously until i unplug it what do i need to do. I'm sure that it is a code i just do not have a manual for the washer and drier.
Anonymous
Level 3:
  • Master 347 Answers
  • Posted on Dec 21, 2010
Anonymous
Master
Level 3:
Answers
347
Questions
0
Helped
84928
Points
1019
You did not mention what model you have..THIS INFO IS VERY IMPORTANT FOR A CORRECT DIAGNOSIS If it just happens to be a Oasis washer it needs a new user interface panel have seen this concern often if it's a different model it my still need a interface panel but the type and model number takes out the guess work......
Atfb6000es1 frigidaire washer beeps ramdomly
Good Afternoon Friend,
I understand that your Frigidaire washer, model# ATFB6000ES1, is beeping randomly. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if you are hearing your washer randomly beeping. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
1helpful
GE Profile model wpgt9350 washer randomly turns on.
It has happened now and again, but in most cases it was traced to the control circuit board. If under warranty, have a technician check it out.
I have a Frigidaire Front Load Washer (FAFW3801LW) that is registering an error code and continuously beeps on and off at random times. I held the start/cancel buttons and E61 or Eb1 popped up. I assumed...
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
4helpful
My unit started beeping continually, I changed batteries, but
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
2answers
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
Remove a memory module.
If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module.
Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
If the computer has a graphics adapter, remove it.
If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step.
If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
Remove a PCI card.
If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card.
Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket.
If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing.
Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case.
1helpful
Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
1helpful
2answers
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Washer flashing fault codes
truthfully, i think you have a malfunctioning board.if all parameters are correct and unit is washing while beeping is taking place. represents board.
Alexander
vince
