Question about Quasar HQ2121 Air Conditioner
Quasar AC unit operating costs
I have an old Quasar model HQ2121MH unit- 115v,60hz,1pa -with a capacity of 11,500btuh. 10.1A and 1.15kw.
My question is what does it cost to run it. I am in RI and have a difficult landlord.
Thanks,
Donald
  • 828 Answers
$.1545 X 1.15 per operating hour. Depending on actual voltage it could be a little less. Computes to $.177675 cents per hour of operation.
http://www.eia.doe.gov/cneaf/electricity/epm/table5_6_a.html
Posted on Jul 03, 2008
Where can I get information for Vector Product model Vec408
Try Googling (vector)(vec408)(manual) without parens.
Jul 29, 2012 | Camping, Backpacking & Hiking
What type of refrigerent is used in a quasar hq2121mh a/c unit?
will be a great idea to get support customer, and ask the company for what type of refrigerant they recommend.
Today are many restriction, and new type of refrigerant
God bless you
May 09, 2012 | Heating & Cooling
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
Should the drain plug be in or out when running a Quasar HQ2121MH window mounted A/C
it should be out and connected to a drain to allow condensate to collect in the drip tray from the evaporator coil and then run away down the drain.
all the best
Jul 05, 2010 | Panasonic Heating & Cooling
The VCMA-20ULS pump is not shutting off
These pumps have a float arm inside that tell the pump when to turn on and off, it sounds like your arm is stuck or broken. The top of the unit can be taken off of the reservoir to check for damage.
Good luck
Sep 29, 2009 | Little Giant 115V 60Hz Condensate Removal...
Overload protection piece is burntout MRA98695
THE TRUE NAME OF THE PART IS A KLIXON SWITCH, THERE SHOULD BE NAME AND NUMBERS ON THE SWITCH SOME WHERE. MEAN WHILE I'LL SEE WHAT I CAN FIND OUT FROM THE MODEL NUMBER. IF YOU WISH CONTACT ME DIRECT AT
tstewart1956@verizon.net
Aug 10, 2009 | Quasar HQ2101SH Air Conditioner
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Jan 22, 2009 | Powerware PW3105 700 (103004248-5501)...
    Quasar HQ2121 Air Conditioner Logo
    395 people viewed this question
    Top Quasar Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
