Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Buzzing and vibration
My tv is exactly 3 years old. i came in the room one night and no picture. there was a loud humming and definite vibration from the rear of the tv. i replaced the bulb and it still does it.....what could it be?
It is the color wheel. you better have the warranty. its pretty much the same cost as getting a new tv
Posted on Jul 14, 2008
When TV is turned on the picture has become darker. This has been going on for a few days and its getting worse.
This sure sounds like a bad lamp. If it is over 3 years old change it.
Also, listen for loud buzzing sounds that may indicate a bad color wheel.
But this definitely sounds like a lamp that is about to go bad.
Feb 10, 2011 | Samsung HLS4266 TV
LOUD BUZZING SOUND WHEN DISPENSING WATER THRU THE DOOR
The water control valve on rear of refrigerator is weakening. That is typical sound for a coil that opens the side that dispenses water or ice tray refills to vibrate or buzz when weakening. If I had you r model number I could give you the part number. They are not expensive and easy to replace. Thanks, Sea Breeze
May 06, 2010 | Maytag Refrigerators
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
TV making loud humming noise
Sounds like u need a color wheel
Apr 06, 2009 | Televison & Video
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Sound at power on
The sound you are hearing is the degausing coil which will vibrate for a second when the tv is turned on. This part demagnetizes the picture tube and this sound is really quite normal. Depending on the position of this coil it may vibrate against the front cabinet of the tv and may sound loud at times. If this really bothers you then you need to have the rear cover removed and have it repositioned a bit do it won't vibrate so loudly. Or you can enjoy the buzz for the short time it happens and not worry about it.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Samsung DLP loud vibrating noise
The color wheel is the most common problem in DLPs that cause noise. To determine the cause: Turn the set off. If the noise goes away after about five seconds, then, the problem is the color wheel. If the noise goes away one to two minutes after shut off, then, the problem is a fan. You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link: http://www.samsung.com/Support/ServiceLocations/index.htm
Apr 22, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Henry  Thomas
Henry Thomas
