Question about Sharp AL 1631 Copier
Printer? Is there a cable available to hook up my al 1631 to my computer and use it as a printer?
  • Anonymous Mar 14, 2014
    can I use the Al-1631 as a printer?
  • Sharp Master
  • 2,794 Answers
If you have a usb port on the left side of the copier, you can use any usb cable the has a D on one end and is flat on the other end.
Some have network connections as well If you want to connect your printer to a router or switch you have that option as well.
Drivers are available at:
http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html
I think it has to have a CS at the end to have USB and network capabilities which explains why there are no drivers for that specific model. If someone added them later on, you can use the al-1641cs series drivers.
Posted on Jul 04, 2008
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
Where is the computer connection to this printer/copier? Sharp AL-1631
If your model number is 1631, there are no provisions for operation as a scanner or printer, it is a copier only.
The very similar 1641CS does have these features.
Jul 07, 2010 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
Cant set up printer with my Macbook Pro and missing CD
You need the Post Script expansion if available for your copier. Most Sharp copiers will need this option to work with Macs.
Oct 05, 2009 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
SHARP AL-1631 COPIER NOT RESPONDING
try re-installing the software, and re-post if necessary
May 14, 2009 | Sharp AL 1631 Copier
Al 1631
Simple you get a PM, new developer.. call an authorized Sharp Tech...
Oct 21, 2008 | Sharp AL 1631 Copier
Sharp copier AL 1631
Make sure that the lock isn't on the scanner. It is located under the left side of the scanner. If it's off there could be binding in the cable underneath the scanner causing binding to happen. The scanner glass can be removed and the tension released. If the cable is moving around too much, it can be secured using scotch tape.
Sep 09, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
120 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
