Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Re: JW199D and Ubuntu Hardy Heron 8.04
I love my new HG and am running it on an AMD64 with Ubuntu 8.04. Generally it works fine but I get one artifact. Periodically I get an apparent random set of horizontal lines. They come and go when the screen refreshes. I thought it might have something to do with the refresh rate settings but no matter what I tried I could not make them go away.
Would appreciate any ideas you have.
Thanks,
E. Travis
    Scholar:
  • 142 Answers
Do you get these lines when you're using any other OS on the machine?
You can download a Live CD for different distros and see if you get similar random lines. www.distrowatch.com is a great source for these.
The other culprits are loose VGA cable connection to your monitor, or loose fitting card on the motherboard (unless it's built in).
If you can't get the lines to go away, then you may want to invoke the 3-year warranty on the JW199D.
Contact info:
Hanns.G Customer Service
Tel: 888-842-6674, Mon - Fri 6am - 6pm PST / PDT.
Email:
webservice_us@hannsg.com
Posted on Mar 05, 2010
Using Ubuntu Hardy Heron - used to work fine, now it authenticates ok but cannot obtain an IP address. problem only started a couple of weeks ago. Previously in use for 12 months or so no problem. tried...
Do you have any other devices that are able to get an IP address? (Trying to see if it is the notebook or router).
If you assign the notebook a static IP can you access the network and Internet?
Mar 18, 2010 | ASUS Eee PC 701 Notebook
Tip
Install Google Chrome on Ubuntu
This is a guide to help you install Google Chrome on Ubuntu Hardy Heron, there are other ways, but this is the one that works for me, hope it will help you.
Ready to give it a shoot?
Step 1 - Update WINE
In order for the Chrome installation on Ubuntu to be successful you have to update your WINE version to 1.1.4.
Type (or copy) this in to your command line -
wget -q http://wine.budgetdedicated.com/apt/387EE263.gpg -O- | sudo apt-key add -
sudo wget http://wine.budgetdedicated.com/apt/sources.list.d/hardy.list -O /etc/apt/sources.list.d/winehq.list
sudo apt-get update
Step 2 – Get all necessary software
Winetricks is a script that will allow you to get all the necessary software you need for this installation.
The last command below will install Firefox into WINE, this is needed for the third step.
wget http://www.kegel.com/wine/winetricks
mv winetricks /usr/sbin/
winetricks riched20 riched30 flash msxml3 corefonts firefox
Install Firefox into WINE.
Step 3 - Installing Chrome
Once you have installed Firefox into WINE, launch Firefox in WINE and go to - http://www.google.com/chrome/
Download and run Chrome setup.
Step 4 – Launch Google Chrome
Once the download and install are complete, type this command to launch Chrome -
wine “$HOME/.wine/drive_c/windows/profiles/$USER/Local Settings/Application Data/Google/Chrome/Application/chrome.exe” –no-sandbox –new-http
Hope this worked for you and you can use Google Chrome off of you Ubuntu system.
on Nov 12, 2008 | Canonical Ltd. Ubuntu
Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure for configuration? Regards, Moiz
First use the following command to see if your card is being detected by kernel.
cat /proc/bus/usb/devices
Then you can use the following script for the installation, you can check if this is for your version of Ubuntu.
#!/bin/bash
#This program automates task of setting up connection for Reliance USB Card on Ubuntu Hardy Heron. This program does not come with any warranty whatsoever. Please use it at your own risk.
# Detect Modem
echo "Modem Detected: $(lsusb | grep -i huawei | cut -d" " -f7-)"
# Get Connection Number from User
echo "Enter Your Reliance Data Card Connection Number : "
read connection
echo "Setting up connection with $connection"
#Install Gnome PPP Package
echo "Installing Required Packages.."
sudo apt-get install -y -q gnome-ppp wvdial
#Add entries to /etc/ppp/ppp-secrets and /etc/ppp/chap-secrets
echo "I:Modifying necessary system files to allow dialing with Gnome PPP..."
sudo chmod 666 /etc/ppp/pap-secrets /etc/ppp/chap-secrets
echo "$connection * $connection" >> /etc/ppp/pap-secrets
echo "$connection * $connection" >> /etc/ppp/chap-secrets
sudo chmod 600 /etc/ppp/pap-secrets/etc/ppp/chap-secrets
#Start Gnome PPP
echo "We are all set.... "
echo "Starting Dialer..."
gnome-ppp &
exit 0
Dec 10, 2009 | Computers & Internet
Ubuntu 8.04 Sound is Very Distorted HELP!!!
You need to add the following lines to /etc/apt/sources.list file or you need to make sure you have enabled Universe and multiverse repositories in /etc/apt/sources.list file
sudo gedit /etc/apt/sources.list
Make sure you have the following two lines save and exit your file
deb http://archive.ubuntu.com/ubuntu hardy universe multiverse
deb-src http://archive.ubuntu.com/ubuntu hardy universe multiverse
Now you need to run the following command to update the source list
sudo apt-get update
Install mplayer using the following command
sudo apt-get install mplayer
if you want to open mplayer just type
gmplayer
or
You can Open from Applications—>Sound&Video—> Mplayer Movie Player
Install libdvdcss2 and w32 video codecs in Ubuntu 8.04 (Hardy Heron)
Support for WMV, RealMedia and other formats has been bundled into the w32codecs package. This package is not available from the Ubuntu repositories due to licensing and legal restrictions.
For Ubuntu 8.04 (Hardy Heron) Users run the following command
sudo wget http://www.medibuntu.org/sources.list.d/hardy.list -O /etc/apt/sources.list.d/medibuntu.list
Then, add the GPG Key using the following commands
sudo apt-get update
sudo apt-get install medibuntu-keyring
sudo apt-get update
For i386 Users install Codecs using the following command
sudo apt-get install w32codecs libdvdcss2
For amd64 Users install Codecs using the following command
sudo apt-get install w64codecs libdvdcss2
Using above download locations you can install most of the mutimedia codecs for ubuntu.
Mplayer Plugin for Firefox
If you want to install Mplayer with plug-in for Mozilla Firefox run the following command
sudo apt-get install mozilla-mplayer
Apr 21, 2009 | Canonical Ltd. Ubuntu
Since update I can not access add/remove, downloads, Firefox, or help on ubuntu OS.
I have never heard of this til now. It might be a stuck package? You can try booting into recovery mode by hitting the esc key at boot time and selecting the top line that ends in "recovery mode" then af the next menu select "fix broken packages". Did you have Firefox 2 and 3 installed or just one of them? Is Firefox running in gnome system monitor after you start it and maybe just not showing the window? The only other thing I can think of to try would be to make a new user and log into that user and try it.
Sep 27, 2008 | Canonical Ltd. Ubuntu
Intrepid Ibex Problem
Read up on what you have and develop knowledge and capabilities that will inevitably serve even better when you (also inevitably, but not impulsively) upgrade.
Sep 09, 2008 | Canonical Ltd. Ubuntu
Ubuntu Hardy
Hi, ok first did you install the server version or the desktop version??? i suggest that you you go to http://www.ubuntu.com/getubuntu/upgrading and follow the step from the version of Ubuntu you have. If you cannot log in the i suggest that you reinstall Ubuntu from the cd you have , now if you prefer you can order a free cd from from ubuntu and you will have the latest intrepid 8.10.
any problem come back to me richardicare@googlemail.com
Sep 07, 2008 | Canonical Ltd. Ubuntu
Cant install ubuntu 7.04 on Excelstor J880 SATA Drive
From what I know, both your motherboard and your hard drive work with Ubuntu. I would try the newest release, 8.04 (Hardy Heron).
Try setting the motherboard into AHCI mode rather than IDE mode (you should be able to change this under hard drive settings in your BIOS)
Also, the problem may be with your optical drive. Try swapping that out.  If you can't solve it from there, if you haven't already, try posting on the ubuntu forums.
Jul 26, 2008 | Excelstor Technology J880 Hard Drive
I've tried to install ubuntu+xubuntu on i686 duron 900? 256ram-
Not exactly sure what you are saying... but you DO have a Duron 700? That is 32-bit. No x64 for you!
If that is not what you're saying. You are saying that you received an Xubuntu alternate distro from Ubuntu? Ubuntu comes in prepackaged distributions for i686 (i386, i486)-32bit and x64-64bit.
You can download the Xubuntu for free at
http://www.xubuntu.org/get
Select the Hardy Heron i686 version. When you install, the installer "should" select the best kernel for your system.
Jul 01, 2008 | AMD Duron , 700 MHz Processor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
168 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
