Labtop Shuts Off After 20min of use tried putting in a new battery and ac adapter please help if u have any ideas it used to last alot longer
    Master:
  • 848 Answers
Try to clean the metallic contact where battery is placed ......there may be some dust which may not allow proper contact
Posted on Jul 03, 2008
My labtop wont turn on
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 18, 2011 | Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
When I plug in my Dell Inspiron 1521 laptop, I get an error message saying it does not recognize my charger, will not charge and will likely slow down my computer's speed/performance. Everything...
Same topic on Dell official community, may it will help.
http://en.community.dell.com/support-forums/laptop/f/3518/t/7311465.aspx
There is high possibility that your adapter is stuffed. Dell have built in a recognition circuitry into the 65w adapters and when that goes, the system will no longer recognize it as a 65w adapter even though it is still putting out 65w. The system then shuts off the battery recharge circuit and to make matters worse it won't even charge the battery when the computer is off. It also speedsteps the processor down to half its speed so everything runs slower. Only option is to stick with a slow computer that can't be used on batteries or buy another ac adapter.
If you do not want to pay $80 for a original adapter directly from dell, there is an alternative choice to get an 3rd party charger, check this link below:
http://www.chargerbuy.com/replacement-dell-inspiron-1521-ac-adapter-19-5v-3-34a.html
Aug 02, 2011 | Dell Inspiron 1521 Laptop
The labtop do work with battery but doesnt work well with adapter instead with will hang or shutdown after 3 or 4min put the adapter
Jul 20, 2011 | Toshiba Satellite Pro L300 Notebook
Compaq evo n610c battery not charging
Dear All,
As per your asking that question the conclussion is there is an problem with battrey not on mother borad either problem is in Adpter connector please check out that adpter conncetor or else in the power connector in your computer iam telling you that there is an no problem in mother borad 100% suerly i tell you,
Regards
Vishwanath.K
Mar 11, 2009 | Dell Microsoft Windows XP Home Edition
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Power problem
Your battery is probabily uncharged or disconnected. Try taking the battery out and putting it back in. Then charge it (by plugging in the AC adapter) until the green activity light stops flashing. If this does not work, your battery is probabily dead. Did you short it out? Or perhaps it is old. Li-Ion batteries (the kind used in these machines) lose their ability to hold their charge in a few years - even if they're not in use! So, if your battery is 3 or more years old, try considering a new battery.
Jan 03, 2008 | JVC GZ-MG130U Camcorder
Digital camera
1. Check batteries.
2. Connect camera to an AC adapter.
3. Remove all batteries, disconnect AC adapter, wait a minute, reinsert batteries and reconnect adapter. Turn on camera.
Dec 01, 2007 | Cameras
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
