Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fault "F2" Hi,  the motor tries to start but shuts down after a couple of seconds, can it be fixed or should i strat saving for a new dishwasher?
  • Frank Jul 13, 2008
    Same problem as stated above can you send me a copy of the service manual to dosbikers@gmail.com
  • 27 Answers
F2 is a motor fault. I suggest removing the stainless steel filter, then the rotor, possible it is jammed but these rotor can seize up. If you are unable to spin the impeller I suggest replacing it.
Posted on Jul 15, 2008
  • 770 Answers
What is your email address i can can send you the service manual
Posted on Jul 08, 2008
My Maytag quietseries dishwasher fills then starts running then stops tries to runagain thenstops 4 times total then just shuts down.
Sounds like the thermal cut out in the motor is opersting. You mist see if the transmission turns freely
  • if it does then a new motor may be needed.
  • if not then there is a transmission fault
  • Then try a new machine.....
  • good lick
  • http://:www.appliances.cjb.net
Jan 22, 2011 | Maytag Dishwashers
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
How to reset whirlpool dishwasher adp4501/5
If you have strat light flashing, hold start button for 3 seconds- this will reset machine. However, the light flashes to indicate there has been a fault detected- count the number of flashes, this indicates fault
Aug 03, 2009 | Dishwashers
Dual dishdraw bottom Ok, top one wont start cycle,F2 comes up
Try swapping the motor rotors between the two drawers and see if the fault changes drawers, also check for anything stuck under the motors or and damage to the plastic of them. cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Maytag MDBTT79AWW dishwasher fills and nothing else. Once filled you hear a click, followed by a humming sound for 3-5 seconds, then silence. This will happen two or three more times, and then unit will...
That sounds like the motor trying to start but being jammed it is shutting off via an internal breaker. Check for something in the bootom of dishwasher that might have gotten down there that could do this. You might have to take the sprayer off and some things below that.
Mar 04, 2009 | Dishwashers
Fault with my dischwasher
F2 indicates the motor is not rotating.The motor may be jammed or defective. Also , the motor rotation sensor may be defective
Jun 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 fault
The F2 error codes relates to high water level It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. As well it could be a defective or a malfunction pump. Good luck!
Sep 05, 2007 | Asko D1876 Dishwasher
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
122 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
