Question about Canon PIXMA MX310 All-In-One Printer
Faxing I send  fax, hear it ringing, hear it pick up, hear it send and then it says, error tx report incomplete transmission result ng
  • debpag Jul 05, 2008
    Did canon offer a solution to help send faxes?
    Thanks
    Problem Solver:
  • 14 Answers
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Too bad Canon can't be bothered to email it's registered users to notify them that the machine they sold us was shipped with defective firmware and attach the fix to the message to save us from hunting for the solution.
Posted on Jul 18, 2008
That is the same problem that I have. I think the settings for the fax have to be reset. I am calling canon to get help.
Posted on Jul 05, 2008
  • rpenczak3 Jul 06, 2008
    That was MY comment. MY helping someone else.
2 Suggested Answers
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Posted on Jul 30, 2009
Incomplete transmission error report on my mx450
Is this a new problem with a new printer, or did faxes used to work okay until now?
Incomplete transmission means fax could not be sent. Many causes.
1. Error on recipient's end or in phone line (fax machine down, too much line noise, etc.)
2. Bad phone cord or bad phone jack on your end.
3. Make sure the phone cord from the wall is securely plugged into the right telephone port on the printer. There are 2 jacks; the important one is lableled "L" for telephone Line In. The other port (with a telephone symbol next to it) is optional, and is to connect to a telephone (only works if you have a phone line already plugged into :L" port).
4. Other causes: see http://www.fixya.com/support/t8747814-canon_pixma_mx860_stopped_sending_faxes
Dec 02, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
report lists the time and date of transmission and whether the transmission was successful
(OK). If you choose On or On+Image, the report will print for every fax you send.
If you send a lot of faxes to the same place, you may need more than the job numbers to
know which faxes you must send again.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
to help you remember.
When the Transmission Verification Report is turned Off or Off+Image, the Report will
only print if there is a transmission error, with NG in the RESULT column.
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Mar 22, 2010 | Canon FAXPHONE L80 Laser
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Aug 10, 2009 | Minolta bizhub 200 Copier
Incompleter transmission causes? Result NG?
It means No Good. 5 possibilities:
Receiving machine unplugged
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Jul 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon fax mp780 says 'ERROR TX REPORT' 'result NG', what do I have to do to to snd the document? The manual has no translation of error codes!
If you go into the fax tx settings and turn off ECM setting, the fax should send (at least it did for me when I had the same problem).
Jun 28, 2008 | Office Equipment & Supplies
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
536 people viewed this question
old marine
old marine
