FixYa.com
Tags:
ASUS P5N-E SLI Motherboard
No signal
posted by emansyndrome on Jul 03, 2008
my computer turns on, all the fans work, but the screen is blank. it says there's no signal. i upgraded my cpu and video card, but that was a little over a month ago and it's worked fine up until now. i've tried putting the old ones in and the same thing happened. no signal. tried replugging, changing the ram, using different heatsink, changing monitors. thought it might be the power supply but i figured i would've had that problem from when i first upgraded. you think it might be the whole motherboard?
specs
asus p5n-e sli mobo
nvidia geforce 8600gt
intel core2duo e8400 3g
liquid cooling
500w power supply
vista ultimate 64 bit
4 gb ram
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 03, 2008
Thanks for Trying (70)
kgjsm397
Rank:Wiz Wiz
Rating: 84%, 53 votes
ensure that you have connected your video cable to nvidia not on mobo video output.
check beep sound look at your mobo mannual
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
nsindian
Rank:Wiz Wiz
Rating: 81%, 65 votes
try taking out a gig of ram and then start computer.
Can you Help with these Motherboards problems?
Motherboards
MSI MS-6754 mother board won't...
I've got a working PC with a... Answer This...
Motherboards
mother board jumpers setting
sis mother board jumper setting... Answer This...
Motherboards
disque cod?
Bonjour,j'ai un probl?me avec... Answer This...
Motherboards
soundcard aspire m1620
i have an acer pc and degrade... Answer This...
my pc fails to go to...
My pc fails to go to... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
