Master
- Posted on Dec 21, 2010
Re: I can't get the rod that connects the key lock and...
Disconnect the negative battery cable with the proper size wrench and place away from the battery.
Insert the key into the ignition lock cylinder and turn the key to the run position.
Remove the steering column cover on a tilt steering wheel
model by pressing the upper and lower section of the cover together and
pulling free from the mounting plate. Remove the steering column covers
on a non tilt steering wheel model by using a Philips screwdriver and
unscrewing the mounting screws.
Disconnect the electrical connector from the ignition switch by lifting up on the release tab and pulling.
Press
the ignition switch actuator pin by pushing a small screw driver into
the key lock cylinder, while doing this pull the ignition switch out of
the ignition switch housing.
Installation
Insert the new key into the new ignition switch and turn the
key to the run position. Insert the new ignition switch into the
ignition switch housing. Wiggle the switch back and forth until the
actuator pin mounting hole is aligned and falls into place.
Install the electrical connector back into the connector housing by pressing it in with your hands.
Place the steering column covers back onto the non tilt
steering wheel and insert mounting screws. Tighten screws using a
Philips screwdriver. Place the steering column covers over the tilt
steering wheel and press the upper and lower portion together to snap
covers back into the mounting plate.
Pull on the ignition key to ensure switch is locked into
place. Turn key to the "off" position and remove the key. Insert the key
and start the vehicle.
hope this helps you
