Question about Kenwood KM800 Major Classic Stand Mixer
The blades in my Kenwood mixer keep slipping out of the housing. I can't see anything wrong with the blades so it must be the fitting inside.
  • jeff6262 Oct 12, 2008
    I have the same problem with a KM005 mixer, There is a spring clip on the shaft of the mixer blade and a recess in the socket the mixer fits into coming from the gearbox, these ar both worn. Obviously the mixer shaft can be replaced (it screws on to the blade) and I am equally sure the socket can be replaced. But knowing appliance manufacturers, I suspect that it won't just be the blade socket which needs replacing, I suspect it will be a replacement gearbox job!!! Can anybody prove me wrong?
  • 99 Answers
Yes! we can supply this part£ 15.00 + p&p shaft size 14mm,If yours is differant size it would be new gearbox.(vertical drive shaft)
Posted on Oct 12, 2008
I have a kitchen aid mixer moder KP26M1XLC, the planatary keeps falling off the mixer housing. Any suggestions on how to repair
You are going to need to remove the top housing and look inside, there is a circlip on the main planetary shaft that retains the planetary and mixer shaft assembly. You may get away with a new circlip but if the groove that engages the circlip is damaged you'll probably need to fit a new planetary as well.
Nov 24, 2017 | Food Mixers
Why won't the blades spin on the mixer ?
what sort of mixer is it? If it is a small hand help are the mixing blades fully inserted up to the little bumps on the side of the rods of the mixer blades where they attach to mixer. If a larger mixer like a kenwood, agin make sure the blade / s are properly inserted.
Aug 18, 2014 | Food Mixers
I cannot get the cord on my Dualit mixer to come out very far.
The cord has twisted inside the housing and is now binding or it has slipped out ofthe housing and is wedged between the cord housing and the case. If it is still within warranty, send it in, if not, you'll need to carefully open the housing to get the cord into the cord housing.
Nov 20, 2009 | Dualit 88520 240 Watts Hand Mixer
What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Jul 19, 2009 | Kenwood KM800 Major Classic Stand Mixer
Mixer runs but blades slip when you add the food
Hi Victoria. There is internal damage in your mixer's transmission. The unit needs to be serviced, and repaired.
Here is something you can try on your own. Unplug the mixer, remove the single screw that holds the silver band. There are now 4 screws that hold the top cover, remove them, and then the cover.
At the top-front of the mixer you'll find the transmission housing. If this housing is made of plastic, check it carefully for cracks in the housing or near its screw holes. If you find any cracks in this housing, you have found the source of all trouble.
Although Kitchenaid advertises "All metal transmission", the truth is that they use a cheap plastic part to support two of the most important shafts in your mixer. This cheap plastic part will fail at some time when it's mixing cookie or bread dough. When it fails the gears and shafts jump out of position and major damage occurs. This is why it was listed on Craigslist. The previous owner wanted to get rid of it.
Kitchenaid's replacement housing is made of metal. Kinda makes you wonder...
Unless you're mechanically adept, you either need to fix it, or get rid of it. If you're not up to the task of repairing it yourself, then take it to a small appliance repair place for an estimate.
If you're looking for a new mixer, go to consumersaffairs.com and search for a make and model of the mixer you're considering and read the actual customer reviews.
Kitchenaid is not what it once was. Steer clear.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
Jan 11, 2009 | Kenwood KM300 Chef Stand Mixer
My moter has gone can ifit a larger one
Hello.
not, you cant, because the screws of the motors 800 fit in different position.
the A701/07 models have 4 screws in the 4 corners. half body.
800w motors have 3 screws in the top .
Regards
Kenwood Chef Restore
Dec 19, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Jan 16, 2007 | Kenwood KM300 Chef Stand Mixer
Kenwood KM800 Major Classic Stand Mixer Logo
95 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
