Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Here i am again, this time just oven not working
Hi jeff, im definately discouraged now.. i had high hopes last night of everything being okay when i was going to try it this morning.
yes the surface burners work fine, always have. And now my broiler is working great.. but im still getting nothing from the oven, theres no glowing even happening.. so im guessing its the ignitor.. which was the last thing i wanted as it seems kinda tricky to replace and time and patience i dont have.
its just weird to me though how the oven goes out and the switch got moved at the same time, i thought by turning the gas lever on and the broiler coming back to life would fix everything.
anymore suggestions on what i can look at before i start shopping around for a ignitor? im so grateful of all your help! i would have never pulled out the range and located that gas lever if it weren't for you.
Michelle
  • 5,911 Answers
Michelle,
Don't get discouraged. I think the gas valve was just one of the symptoms and not the cause. Now that you've gotten that figured out, you probably have a bad igniter on the bake manifold. This igniter goes bad more frequently because the bake feature is used more often than broil. If you click on the link below, I have provided step-by-step instructions on how to replace an igniter:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
This also provides some good information on different types of igniters and current readings they should be. This is actually an easy repair if you follow the steps and take your time. Just make absolutely sure you unplug the range before servicing. Post back and let me know if you have any questions.
Jeff
Posted on Jul 03, 2008
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
Model XL1400. LAst night quit heating. Everything else appears to be working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I started the self-cleaning process on my GE electric oven last night. The process is complete but the oven door will not unlock. It sounds like it keeps running and running.
Hi
You can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if it wont work then press the CANCEL button for 20 seconds. If the issue returns then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | GE JTP15 Electric Single Oven
Our kenmore microwave stop heating.. Everything works well but it just stop heating last night after l cleaned it.. did I do anything to it??
heatman101
78g
May 15, 2010 | Kenmore 63792 Microwave Oven
Have ge sensor microwave model Je1660w
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
Microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
Jun 23, 2009 | Panasonic NN-T654SF Microwave Oven
Jeff Gordon Blender blew up
Sorry to say we do not repair. You will have to contact sunbeam here at this link for service.
http://www.sunbeam.com/index.aspx?section=kitchen
Good luck and Please Rate FixYa1!
Dec 28, 2008 | Sunbeam Jeff Gordon NASCAR 12 Speed...
Microwave works fine, but wont heat food....
I would say the high voltage rectifier diode has blown.
See http://www.gallawa.com/microtech/diode.html for help in diagnosis.
Okay, now that I see the model number, that's a US model:
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Sep 22, 2008 | Microwave Ovens
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
91 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
