Question about Pioneer DEH-P6700MP CD Player
NO SOUND There is no sound coming tru to the speakers
I had a repair and my service order number is 01097943998726 could someone please contact me at 2056013072
Posted on Jul 04, 2008
My 15”Jenson pa speaker. Is not working . Very little sound coming out
If it's only on one speaker the first check if the cable from the amp to that speaker is not ripped off .Tru swopping the speaker around to the side which is working if it still has no so sound the maybe you should check on the amp to see if you did not cut the stereo down for that channel .See that the balance dial is in the middle. Last of the easy stuff to check is to take your headphones and see if you get even volume of both sides don't forget to check if there is a stereo/mono switch you want this switch to be set to stereo though the sound will no change much cause your bass may be a little lower on mono.When you have finally tested all of these and no satisfaction, then one of your transistors of that channel is blown. But it can also be a cap that is leaking or blown.You can open the amp but disconnect the power before touching or opening .Look at the channel which is not working to see if you have a cap swollen or blown then replace it with it's same value micro farad (pf).It's difficult to say what else can be wrong but those are the first to look at.It will take even me around a hour to say whats wrong .Fault finding is what takes time . good luck
Nov 15, 2017 | Music
I have a ZVOX 580 soundbar. Using the digital optic cable I have no sound. I have sound through RCA cables. Can you help?
They to check the menu of the TV is there is any option to activate the Digital out or is there is any setting which allow you make a selection between internal speaker or external speaker. if its there the make the setting as external speaker .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 15, 2016 | ZVOX ZBase 580
RCA Tru Flat 20" TV/DVD Combo Remote and manual
Hi
Check its speaker first. If it is Ok, check whether the volume is set to zero, or mute function is ON. If all of the above is OK, the audio output IC of your tV is faulty. You ahve to replace it with same type and number. Audio IC can be located by following the speaker wire. One end of that wire will go to oudio output section. There will be an IC; usually screwed on to a metal heatsink. Check its solder terminals first, for any loose soldernng. It is best to resolder all the solder terminals of that IC, by applying a little more solder, without making any solder bridge in between adjecent solder points. If this resoldering also does not help you, check the voltage at the pins of that IC. The maximum voltage will be between 25 and 24VDC. If the voltage also is there, and still there is no sound, replace the IC with same type and number, provided the speaker is good. OK.
Jul 12, 2011 | RCA 20F610TD TruFlat TV/DVD
Loving the HD tv...have noticed a problem with my surround sound though. My kenwood amp auto sense's dolby digital 5.1 and some BD do work in DD 5.1 but most don't. It says DD5.1 on the package and the...
Your A/V Receiver must have the decoders for the source on the BD and for the newest audio surround sound you should be using a HDMI cable to the A/V receiver because the SPDIF optical or digital coaxial cannot handle the Dolby TrueHD and other newest codecs. Probably you are getting the down-converted audio because of this.
Mar 17, 2011 | Kenwood Audio Players & Recorders
No sound is coming from my speakers &headphone
no sound is coming from my speakers
May 18, 2009 | HP Sound Card
My sennheiser hd 212pro headphones has only the left side speaker working, the other side has no sound. i pulled them apart to see if anything had come lose and nothing has, i dont know wat is wrong with...
One speaker element may be blown or wiring may have internal break. It may be cheaper to relace the phones rather than having them serviced, unless they are still under warranty
Aug 19, 2008 | Audio Players & Recorders
Rookie to Sound System
are u runing tv throw system and video ? with hdmi then back up to tv hdmi best to run hdmi cable from dvdplaye rto tv direct ok then dish box ect cable hdmi out direct also to tv then use optical out put digital on tv outto sterio digital in on back ok for tru 5.1 best way to do this is this way
Jan 30, 2008 | LG LHT734 System
Sound not coming out of the rear or center speakers
Sort of confused a bit I understand you buying a new system you say the sound does not come out the rear and centre speakers does the sound come out of any spearkers other than the two you mention if it is then your wirings are wrong if the sound is not coming out of any speakers then its the sound card BUT you will know this immediately you disconnect that system. The sound would be coming out of the laptop ordinaryly? which is it?
Sep 04, 2007 | Logitech X-530 Computer Speakers
No sound during playback
you need to check whether sound is ok tru av out leads ,or is it problem with no sound while trying to play back in camera as have seen a few of these with internal speakers going faulty.if you try it tru av leads you should have sound if this is the case
May 09, 2007 | Samsung SC-L906 Camcorder
Pioneer DEH-P6700MP CD Player Logo
75 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
