Can i hook up a outdoor wood boiler to a colman mobile- home forced-air furnace, if so what do i need?
    Novelist:
    Champion:
  • 230 Answers
I would check with your local building codes before investing any money with this issue.
Most companies will do free or cheap onsite bids. They should be able to give you a complete break down of what you might need and the related costs.
Posted on Jul 03, 2008
I have a 1984 Colman propane furnace that is short cycling
Why does the gas furnace short cycle - YouTube
? 11:07
https://www.youtube.com/watch?v=3LBut8fWcw8
Apr 23, 2012 - Uploaded by grayfurnaceman
When the gas furnace short cycles, and it does not bring the structure up ... have a frazier Johnson furnace with 9 blinks on diagnostic light. just ...
Mobile Home Furnace Troubleshooting - Mobile Home Repair
www.mobilehomerepair.com/articlefurnace.php
Jan 17, 2016 | Heating & Cooling
Tip
How to Hookup Your Outdoor Wood Boiler
You just bought or a thinking of buying an <span style="font-weight: bold;">outdoor wood boiler.</span> How do you integrate that boiler into your existing <span style="font-weight: bold;">home heating system</span>? The guy selling you the boiler wants the sale and tells you that hooking it into your system is very simple.<br /><br /><span style="font-weight: bold;">Outdoor wood boilers </span>come in many shapes and sizes. For the most part bigger is better for these things. The next thing you need to consider is whether the <span style="font-weight: bold;">boiler is an open or closed system</span>. It does make a difference in the way it gets hooked up. <span style="font-weight: bold;">Closed systems</span> can be hooked right up to your <span style="font-weight: bold;">existing boiler system </span>in a <span style="font-weight: bold;">primary secondary configuration</span>. This means that the wood boiler circulates to two tees in your home system and the home system circulates the water through the home. The two waters mix through the tees.<br /><br />If your wood boiler is an <span style="font-weight: bold;">open system</span> then you need to install a <span style="font-weight: bold;">stainless steel flat plate heat exchanger </span>to divide the two waters. The hookup of the <span style="font-weight: bold;">heat exchanger</span> is not that hard if you follow the instructions properly. This heat exchanger is very effect in<span style="font-weight: bold;"> transferring the heat</span> from the wood boiler to the inside heating system. It also keeps the water of the<span style="font-weight: bold;"> inside system pressurized and isolated.</span><br /><br />If you are installing your outdoor furnace to a <span style="font-weight: bold;">hot air heating system</span> then you need to <span style="font-weight: bold;">buy a coil</span> similar to your car radiator to install in the plenum on the supply side of your <span style="font-weight: bold;">existing hot air furnace</span>. To this coil you will <span style="font-weight: bold;">hookup the water pipes from the outdoor boiler</span>. The water running through the coil will heat it up so that the air going through from the <span style="font-weight: bold;">hot air furnace </span>will be warmed. The water hookup for this style of heat is very simple, but the <span style="font-weight: bold;">electrical hookup of the blower, pump, and circulator </span>may not be as simple. You may need someone with a good electrical knowledge to make everything happen in the right sequence.<br /><br /><span style="font-weight: bold;">Outdoor wood boilers can heat your home effectively </span>if they are <span style="font-weight: bold;">installed to your existing heating system properly</span>. If they are installed properly you will notice no difference in the heating of your home. It will be <span style="font-weight: bold;">warm and comfortable.</span> Make sue that you do your research properly before trying to <span style="font-weight: bold;">install your outdoor wood boiler.</span>
on Feb 21, 2011 | Heating & Cooling
Tip
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to get the heat from the wood stove to the living space.
If you have a hot water heating system already installed then you obviously need to have a water stove. If you are thinking about what to install in a new home or already have hot air then you need to consider what will be the best option for you.
Now if you are installing a new system then you want to go hot water. That is by far the best way of heating and will be the best way to heat using an outdoor wood stove. Hot water heating is one of the best ways to get great heat transfer from the fire to the water to the air.
If you have hot air heat and want to heat with wood then you can install a wood hot air furnace, and set it beside your existing furnace. The ductwork will have to be reworked to get the heat from the wood furnace to the existing ductwork. Or you can install a coil into the ductwork on the supply side of the furnace, for the water to run through from a hot water wood burner. This is probably the best way to heat if you have a hot air furnace. Installing the hot water coil is a very simple process and the piping is fairly easy to hookup.
Hot air wood furnaces are almost always a inside the structure appliance, which means that you have the mess of the wood and the ashes inside. This dust and dirt mess is something that is much better kept outside where it can be cleaned up much easier.
Bottom line here is that you want to use a hot water wood burning stove if you can. You will be much happier with the heat that you get from burning wood.
on Dec 08, 2009 | Heating & Cooling
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
We have a Colman Direct Vent Forced Air furnace, Model 7970A856, in our mobile home. We just moved in. We cannot get the pilot to light.
thermocouple is bad, thats the little probe that sits in the pilot flame, and runs back to the gas valve
Oct 23, 2010 | Heating & Cooling
Tip
How to Hookup Your Outdoor Wood Boiler to Your Existing Heating System
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You just bought or a thinking of buying an outdoor wood boiler. How do you integrate that boiler into your existing home heating system? The guy selling you the boiler wants the sale and tells you that hooking it into your system is very simple.
Outdoor wood boilers come in many shapes and sizes. For the most part bigger is better for these things. The next thing you need to consider is whether the boiler is open or closed. It does make a difference in the way it gets hooked up. Closed systems can be hooked right up to your existing boiler system in a primary secondary configuration. This means that the wood boiler circulates to two tees in your home system and the home system circulates the water through the home. The two waters mix through the tees.
If your wood boiler is an open system then you need to install a stainless steel flat plate heat exchanger to divide the two waters. The hookup of the heat exchanger is not that hard if you follow the instructions properly. This heat exchanger is very effect in transferring the heat from the wood boiler to the inside heating system. It also keeps the water of the inside system pressurized and isolated.
If you are installing your outdoor furnace to a hot air heating system then you need to buy a coil similar to your car radiator to install in the plenum on the supply side of your existing hot air furnace. To this coil you will hookup the water pipes from the outdoor boiler. The water running through the coil will heat it up so that the air going through from the hot air furnace will be warmed. The water hookup for this style of heat is very simple, but the electrical hookup of the blower, pump, and circulator may not be as simple. You may need someone with a good electrical knowledge to make everything happen in the right sequence.
Outdoor wood boilers can heat your home effectively if they are installed to your existing heating system properly. If they are installed properly you will notice no difference in the heating of your home. It will be warm and comfortable. Make sue that you do your research properly before trying to install your outdoor wood boiler.
on Dec 03, 2009 | Heating & Cooling
Aprilaire
Commonly outdoor wood boilers use a hot water coil mounted in the ductwork above your furnace. In this application the Ruud furnace is still using its blower assembly to circulate the warm air from the boiler to your home. If this is the case. Have your heating guy install a #50 relay on the furnaces blower motor to activate your much needed humidifier. If this is not the case and your Ruud furnace is totally independent of the boiler. Still install the #50 relay in the furnace and manualy activate the fan only feature on your thermostat.
Good luck
HVAC Teacher
Feb 21, 2009 | Aprilaire 600 Humidifier
Colman Furnace keeps kicking on & off
Denise, my heater not a coleman (a monitor heater (oil) kept turning off when the temp got really cold. I would advise you to ask if you can do this, I addded an additive to my drum outside which holds the fuel. Because the deisel thickens up when it gets cold, which makes the heater have a harder time distributing the fuel to the heater. So far the heater has not kicked off.
Jan 09, 2009 | Coleman Propane Forced Air Heater...
Installing a boiler
Set the Miller to turn on at 7-10 degrees lower than your wood boiler. Make sure the Miler works by turning up the t-stat 10 degrees higher than room temperature first.
Sep 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
Colman furnace
look on your burner control relay - look for terminals marked T and TH.  connect up a honeywell thermostat here.
Oct 03, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
