Texas Instruments TI-89 Calculator Logo
Anonymous Posted on Dec 21, 2010
When i try and install noteflio on my ti-89 titanium it says its not compatible?
  • 29 more comments
  • Anonymous Dec 21, 2010
    What type of operaitng software are you using?
    I am using windows 7 64bit
  • kakima Dec 21, 2010
    Are you trying to install the TI-89 version of Notefolio, or the TI-83/.84 version? The two are completely different.
    I am using the one that say its for the ti-89
    What version of the operating system do you have on the TI-89? Press F1 and select "About..." to see.
    its the newest one i checked last night... like 3.0 i think... ( my calc is in my car right now :) )
  • Anonymous Dec 22, 2010
    What other APP's or APP files do you have on the calculator?
    Calculator OS is not the problem. Hopefully, you have 3.10 OS for your operating system. Please list the APPS you have on the calculator, and APPS that you may have been trying lately.
    Have you tried to take everything off the calculator including APPS, and downloading notefolio by itself? If that works then I'll post what the exact problem was so that you will know.
    I tried to take everything off my calc but couldnt figure it out :)
    How do i do that
    And i have very few apps...
    See if you can back-up what you have on the calculator with Ti connect. to the computer. Did you download something lke Ti reader or Ti study cards? I think you have something in the main folder, APP varible or something that is causing the conflict.
    that this is the very first app i have tried to install, I just have a couple original apps, however a long time ago it seemed like a lot of them disappeared.....
    Are you willing to do a complete reset? You have to re-install everything.
    Yes that is fine, as i dont have anything on there....
    What was the first APP? Ti reader? or cards?
    i dont have either of those and i didnt try to install them the very first and only app i tried to install was noteflio
    To do a reset 2nd-key, then MEM same as the 3 key. Then F1, then 3.
    So you never got the calculator to download any thing? If so we may have a windows 7 64 bit problem.
    Ok its complete... I have the same apps on there as before..
    You can't tll me if you have any APPs on the clculator? What does 2nd key , then MEM. What does it say for flash ROM free?
    What APP are on the calculator? They should have all been deleted? Just keep answering.
    clock, data/mat, graph, home, numeric solv, program edit, table, text edit, window edit, y=editor
    all memory is 0 except system which is 68158, ram free 193986, flash ROM free=2621362
    Ya, those aren't APPS. That is embeded programs. You are using Ti connect. Right?
    You can go to cnet.com and download and install, Free Windows Registry. I'm not sure if it will work for windows 7 64 bit. I'm beginning to think it is the 64 bit that's the problem. Or can you try a 32 bit xp machine?
    Yea, not to restore right??, but when i try and install noteflio i am using ti-connect yes
    ok i have an old crappy comp in my basement with xp i will go try and get ti-connect and then install noteflio
    Ya, you have nothing on the machine to conflict with. It has to be 64Bit problem. And that can't be fixed. Try an XP machine or the Free windows registry. Registry work for me but, I have 32 bitmachine
    Keep me informed. I haven't sleep jet. But, will get you on your way. So you can get the most out of your calculator.
    Let me know if you get any errors. I might be able to fix it real fast.. See that is why the first thing I asked was what you OS. I thought it might be that or a Ti reader APP conflict. Ti did tell me about the 64bit problem. I was hoping not to run into it.
    If you can get notefolio creator on you old xp machine you'll might have to have the registry fix. But, its worth it if you can get things going.
Anonymous
Level 2:
Novelist:
  • Expert 100 Answers
  • Posted on Dec 22, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
100
Questions
0
Helped
100332
Points
237
You probably have a windows 7 64 bit OS problem. Nothing can be done with TI downloads because, it is incompatible with TI connect. Try another machine that has more of a 32 bit OS.
Testimonial: "very helpful thanks :)"
  • 6 more comments
    hen you go to another machine, if Ti connect won't install you might have to install Microsoft Netframe 1.1. at least. The computer probably tell you.
    Ok it works on my old xp system...So either the problem was windows 7 64-bit OR i plugged in my calc to my window 7 comp before install ti-connect and it never got the right driver installed...
    Thank you very much!!
    (PS: my window 7 comp was telling me to install netframe 1.1,,,, i did and nothing happened o well :) )
    If you run into problems go to this site and stroll down to " Troubleshooting-Errors Messages-Unexpected Results" and see if you can find a solution that can help you. Plus, I'll still be here too. http://epsstore.ti.com/OA_HTML/cskmbasic...
    Great!!
  • Anonymous Dec 24, 2010
    Try this procedure. See if we can get your Windows 7 to work. Understand it still might not because, of the 64 bit. However, it's worth a try, and Ti will tell you if it is because of the 64 Bit. Be sure to post on this page if it works.
    Windows Vista and Windows 7:
        • Go to your Start Menu and search for Device Manager.
        • Open up Device Manager.
        • Scroll to the USB controller and click the .
        • Turn the calculator ON then connect the USB cable to your PC. A new device will appear on the
    USB controller.
        • Right-click on the new device and choose Update Driver Software. The Hardware Update Wizard
    will appear.
        • Choose "Browse my computer for driver software"
        • In the search field type in C:\Program Files\TI Education\Driver Files
        • Click on Next to finish installing the driver properly
        • Once the driver is installed click Finish
    4. Try a different cable and if possible a different computer.
    5. If trying different cables/computers fails, please contact us. Attach a system information file to the
    email reply you receive from us.
    To get system information:
    Windows Vista / Windows 7:
       • Go to Start Menu and search for System Info
       • Once loaded, click on File and choose Save
       • Name the file FirstNameLastName.nfo
       • Please check to make sure that system info file(.nfo) is the selected type of file
       • Attach the .nfo file to the email reply
    Click the sign.
    Click the plus sign.
  • Anonymous Jan 15, 2011
    http://www.fixya.com/support/t7610505-ju...
1helpful
2answers
TI-89 Titanium screen frozen at apps menu
Remove the small memory battery, and then remove one of the four AAA batteries, then while holding down the APPS button reinstall the AAA battery and then it should say waiting to recieve operating system then hook it up to your computer with the silver connect cable and then on the computer send the operating system to the TI89 Titanium, and wait for it to install completely and it should work.
1helpful
Ti-89 titanium diagnostics
There is no DiagnosticsOn command in the TI 89 Titanium. The command exists on the TI83/84PLUS where it displays the r and r^2 coefficients. On the TI89 , the correlation coefficient and the determination coefficient (r, r^2) are displayed by default among the statistics if THE REGRESSION MODEL includes them. If they are not defined by the regression model they will not be displayed. In short, you do not have to turn diagnostics ON.
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
1helpful
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Ti 89 Titanium
The only option or keys that will work is the ENTER key and the arrow keys. Try to get your arrow key to work by arrowing down and hit enter hopefully change you to something different.
Next, if at all possible can you hit the MODE key or get into the mode. If you get into the MODE select F3 and then arrow down twice or all the way to the bottom and at APPS Desktop select 1:OFF and then hit the ENTER key. Next, What I really think you need to do is reinstall the Ti 89 OS software. To do so you would need to connect to your computer or another Ti 89 Titanium to your Ti 89 Titanium. If you have Ti connect computer software (from the Ti site) connected to your Ti 89 Titanium it might help you more in troubleshooting any further problems too. You might be able to delete corrupt files that would free your calculator up and start running better.
14helpful
2answers
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
2helpful
3answers
TI-89 Backup Battery
Usually you will be able to re-install everything. And I would try uninstalling the program first then if that doen't work just pull the batteries out and put them back in or just press the reset button. Hope this helps. =)
Not recognized by computer when plugged in
look for TI-89 titanium drivers and install them to your PC. then connect ur calculator and it should be working.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
