Question about ASUS P5S800-VM Motherboard
P5s800vm Hi in my system USB port is not working please send the USB Drivers Data thank full thank full to Asus System regards
  • 84 Answers
If you run XP , or Vista you don't need USB drivers . Purchase a PCI-USB card
Posted on Jul 31, 2008
Hi., How do i download wifi drivers for dell inspiron mini 32bit 1.67GHz wimdows 7 ultimate?
at dell sight should have drivers,to update. That would be my first guess.It might not be supported anymore. If not ,manufacturer of WIFi. They make wifi that plugs into USB port for $20-$30 a dongle, and will have new drivers
Feb 11, 2015 | Dell Inspiron Mini 10 Notebook
Tip
P5s800-vm
Hi
regards
on Jul 03, 2008 | ASUS P5S800-VM Motherboard
Tip
USB Problems
Hi
regards
Buvanachari
on Apr 05, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
All my usb port not working some need replaced how do i go about it
dianeike,
Unfortunately usb replacement on laptops can be very expensive if they are physically damaged. As inexpensive as laptops are getting these days it just does not make sense to put to much money in them unless you have a very expensive laptop. As for your problem with the usb ports if they are not physically damaged you can reload your drivers. This is the best option to try to make them work again. You need to go the manufacturer website and download the drivers for your usb ports on the make and model laptop you have and install them. If you do not know how to find them please reply back to me with the make and model laptop along with the operating system you use and I will be glad to send you the link and you can install the drivers. If you have at least one usb port working you can always buy a usb hub.
Thanks for visiting Fixya.com. Have a great day !
Regards,
TechGuy21
Jul 07, 2011 | Computers & Internet
P5b-e mother board: USB ports on MB stopped working with operating system (have tried win & and XP). All ports work if running op system from disk
I would update the bios, uninstall the drivers for the ports, download the latest, and reboot. If the machine recognizes the ports, it will begin searching for drivers. Interrupt the search and manually install the drivers. If this does not good, I would reinstall the operating system. Also, use the drivers from ASUS...
Jan 03, 2010 | ASUS P5B-E Motherboard
Hi, my system not working properly.
I don't think this is a BIOS problem. Sound more like you need to re-load windows and start from scratch. Make sure your USB is turned on in the BIOS.
Dec 25, 2009 | ASUS M2N-MX Motherboard
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Can't install SimpleTech 160 gigabytes
The usb port in your compute dosent support usb 2 please change the port if your system is latest dont connect both the usb cables of the hdd cauz the latest system is with usb 2 and dosent need power if old system please connect the power usb first and then the data usb cable it should work
please also try to connect to another port of your pc if available
thanks and regards
DUSHAYaNT
Jan 03, 2009 | SimpleTech Signature Mini 160GB External...
Usb
http://www.driverfiles.net/Bios/ASUS/P4S8X-MX/download/page,sh,29990,172,6,.html
download your drivers here
Sep 05, 2008 | ASUS P4S8X-MX Motherboard
A USB mouse will work but the PS/2 mouse failed. What causes it?
Hi melch, On the PS/2 mouse, chances are that the surface mounted fusible link/resistor supplying the +5VDC is open. It is normally very near the PS/2 port and marked [0] or labeled F???. This can be verified by measuring the absence/presence of +5 at pin 4 of the connector. In some cases, it is the I/O chip that gets damaged. Re "only two(2)USB port" aside from the 2 rear USB ports, the Asus CUV4X-C has another pair of USB connectors that are normally connected to the front panel of the casing. It is located very near the motherboard battery. Re "...prompting...high speed USB port...", normally by updating your OS (say XP to SP2) or downloading/installing latest VIA 4 in 1 Drivers should make your USB 2.0 compatible. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
ASUS P5S800-VM Motherboard Logo
229 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
