WHERE IS THE PRESSURE SWITCH LOCATED ON A ZANUSSI AQUACYCLE 1000 XC WASHING MACHINE
    President:
  • 1,462 Answers
As i remember, it is located underneath the crossbar on the top of the machine, visible when you remove the worktop
Posted on Jul 04, 2008
Access motor belt zanussi aquacycle 1000
There is usually a hatch at the back of the washing machine.
Mar 17, 2014 | Washing Machines
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Drum fills withe water when machine is not in use
Can you turn off water to machine? The water seleniod needs to be replaced this lets water in the switch sounds like it's stuck open.
Jul 26, 2010 | Zanussi ZWF1420W Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
I need instructions for zanussi aquacycle 1400 XC
My washing machine dials won't light up and strait but the power is switched on
Jul 03, 2009 | Zanussi F1245W Front Load Washer
I need to know what the model no is for a zanussi aquacycle 1100 xc washing machine as I have a problem with the drain um and would like to urchase a new one but do not know the model no of the machine
if you look on the back of the machine there should be a label there with the model number. (Or inside the users manual)
http://www.zanussi.co.uk/ or go here and click on 'Contact Us' to find out directly fron Zanussi.
Nov 08, 2008 | Washing Machines
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Washing Machines Logo
309 people viewed this question
Top Washing Machines Experts
