Question about Honeywell Heating & Cooling
What temperature should be set on a honywell 4 cycle thermost during the summer months
    Novelist:
    Champion:
  • 230 Answers
To gain the most efficiency, please visit your local energy companies web site. They will list the best temperatures for your region to save the most amount of money. The EPA has some good information regarding this issue as well.
Posted on Jul 03, 2008
Refrigerator freezing up
I was told by Sears to turn my thermostat to the refrigerator side down in the summer months to eliminate the freeze up. Seems that opening the door more often in summer makes it think it needs to dool more.
Jun 03, 2014 | Refrigerators
My 1994 ford explorer (166,000mi) runs great during colder months, whether city or hwy and upgrades or downgrades. During warmer months, since last year and now this year, it loses power (from 65-45,in...
thanks for giving a good deal of info to go on. When i think of what temperature will have an effect on I think of oil. Oil would work better in winter because it is thicker and lubricates better. In summer it will thin out and maybe with the higher mileage it has an effect on the motor power. What oil was used on the last oil change. Most popular is a 10w-30w. Maybe summer would be better to use straight 30w. If this helps please reply and good luck
Apr 27, 2010 | Ford Explorer Cars & Trucks
Thermostates not work properly,
I had the same problem just read the instructions very careful and you will be able to figure that out. I mine has two settings in the morning and two settings in the afternoon.
Jan 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
May 08, 2009 | Washing Machines
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
When you start a cycle, a small amount of water will run into the washer and it will sit and do nothing then the pause button flashes. But it will not finish a load even if you continue to hit the pause...
Apr 01, 2009 | GE WBVH6240F Front Load Washer
Rising cycle
Have you 'proofed' your yeast? The rise temperature is not very much above room temp, particularly in the summer months. I would expect the bread to rise at least 3/4 as much without any rise time heating.
Jul 07, 2008 | Zojirushi BBCC-V20 Home Bakery Traditional...
What tempratues should be set on a honywell 4 cycle thermost during the summer months
As a general rule set your t.sat 20 degrees below outside temp. Leave at this setting 30-45 minutes. Move down until comfortable no lower than 10 degrees below outside for 30-45 minutes. Unit should cycle normally. If it runs continuously then raise the t.stat 3 or 4 degrees up. The national average is 75-78. I usually keep mine set at 80 during the day here in Georgia and 74-78 at night...
Jul 03, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
62 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
