Whirlpool SF367 Gas Kitchen Range Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Whirlpool SF367LXSS oven does not work on bake or broil. The top burnes work well. The oven clicks like it is trying to light but there seems to be on gas to the oven.
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Dec 21, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10845199
Points
101584
Check the gas valve to see if it is getting power to open it....if it is then it has gone bad...
The ignitors can also cause this but not likely that both will go at once...
Also many oven/broilers have a separate regulator and that could be locked up... often because of high incoming gas pressure...
heatman101
8helpful
2answers
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
1helpful
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
2answers
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 • GE Ovens
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 • Ovens
No heat on the upper oven bake and broil elements
I gather you are measuring voltage with respect to the chassis ground?
http://www.appliancepartspros.com/07-wiring-information-parts-for-maytag-cwe5800acb.html
Shows the internal wiring for the unit. The parts are rather expensive and some are no longer available.
Whirlpool range
hi the part # is AP 3008287 at Appliance parts pros.com infinite switch controls the top burners thanks the appliance doc
Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
