Question about HP LaserJet 4100n Printer
HP Laser Jet 4100n Printer
Two days ago our HP LaserJet 4100n started a high pitched ring each time in is printing. The printe quality is fine. The ring is annoying and I would like to fine a solution to stop it.
I had a similar problem with one of mine. Turns out that the output voltage on the surge protector was different than the wall outlet somehow. If it is plugged into some secondary device, unplug it and plug it directly into the wall and see if that remedies the problem.
Posted on Sep 03, 2008
  • HP Master
  • 691 Answers
This sounds like the swing plate assembly is starting to wear. It is not a job your average user can complete and It may be worth getting an HP eng to have a look for you.
Ring their technical helpline as their call center tech guys are red hot on diagnosing the issue on the phone.
Posted on Jul 03, 2008
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
How do i cancel a printing on my laserjet 1100a
The document you sent to the wrong printer is still in the print queue. You need to go into the print queue and delete the document there. You may need to click to control panel, click on the laser jet printer and delete the wrong document.
Dec 15, 2017 | Office Equipment & Supplies
We have a HP Colour Laser Jet 3600n. We have
nope...... the problem as you rightly poit out is the cartridges, most refills are poor quality and dont last, but the real ones are expensive but very rarely cause issues. If one colour is dodgy the entire colour process fails, print a square of each colour to determine which colour cart is the issue and complain to seller, 99.9% of print quality issues with these HP's is due to non gen toner....not much you can do, expensive is colour printer fullstop.
Nov 06, 2009 | HP Color LaserJet 2600n Printer
The printout is low quality not smooth ?
Generally with all laser printers the print quality is low when compared to that of a inkjet printer. Try cleaning the Printer Cartridge and u can make good quality print outs by changing the settings at the time of printing. Use your Laser Jet printer software from HP and clean the device.
Oct 21, 2009 | HP LaserJet 3800n Printer
Printer
Try this: '''Cleaning page'' in the menu, 1,2.3 times. The quality of print out getting better.
This solution is temporary, for a few pages in one day.
If the printer is used with high intensity, there is necessary to change the Fuser Unit for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v)
Oct 02, 2009 | HP Color LaserJet 2600n Printer
HP 4100N Printer prints too light.
Hi hooperengrg:
I have worked on hplj4100's for years and have ran in to this plenty of times.You will have to have the laser motor mirrors cleaned.That means removing the top cover and cleaning the toner and paper dust build up that has accumulated on the laser motor mirrors that is preventing the laser light from a 100% unobstructive scan to the photo-conductive drum inside the toner cartridge. I hope that this helps
Paul
Mar 25, 2009 | HP LaserJet 4100n Printer
Color laser printers. Costs for toner vs. initial costs for ptr
Have you thought about having your printer cartridges refilled? There are huge savings to be made in doing so and the quality can be just as good as the original cartridges (depending upon the refiller). Another option would be for you to purchase an older color laser printer such as the HP Color Laserjet 4500 or 4550. I use one myself and couldnt be happier with it. And as its an older printer, you can get the cartridges relatively cheap.
Jan 24, 2009 | Xerox 4500 Laser Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
Printer Pauses every few pages, seems to print slower than it shouls
More likely to be Network print spooler issue, check settings on driver.
Nov 09, 2007 | HP LaserJet 4100n Printer
Laser Printer Cleaning
Does the dirty background get lighter as you print additional pages? Have you tried a new cartridge yet? Unless your toner cartridge is leaking toner (you?ll see toner on the inside of the printer or leaking out if you remove the cartridge and shake) a simple cleaning is probably not the answer. Let me know and we'll pick up later.
Feb 28, 2007 | HP LaserJet 4100n Printer
HP LaserJet 4100n Printer Logo
90 people viewed this question
Ben Johnson
