Question about SanDisk Sansa m230 MP3 Player
Mah sandisk my sandisk Mp3 (1 Gb) has stopped turning on but the thing is that it still turns on when i plug it in but after i unplug it it turns of and i cant turn it on.... any suggestions does it mean i have to buy a new 1?> any halp from u ppl @ all?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 05, 2008
San disk cruiser 64 GB will not open
First try unplugging the drive, shutting down the PC, no warm boot, turn OFF.
Now with the PC off plug in the drive, now restart.
Now go to start, control panel, admin tools, computer mgnt, storage, disk mgnt, now do you see the drive, if you do at the bottom, RT click on it and then change the drive path, use a letter above G.
Apr 15, 2013 | SanDisk Cruzer Glide - USB flash drive -...
Blank screen after charging can turn it on
Get to the store where you get it may be it´s damaged
Hope this help
Jun 24, 2009 | SanDisk Sansa m240 MP3 Player
My sandisk sansa 2g wont turn on with out being plugged in at tha computer n seems to be fine when its plugged in but when its unplugged it wont work! the battery is on a full battery but wont turn on at...
The battery may show "full' but still not hold a charge, so that when you unplug it from your computer, it goes dead. I assume you hold down the power button for several seconds and it still doesn't power up? Most likely, you battery is defective.
Feb 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa 2 gb clip stays at writing when plugged in and refresh
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jan 25, 2009 | SanDisk Sansa Clip MP3 Player
Wont turn on
mine is SanDisk SDMX4-2048-A70 Sansa e250 2 GB MP3 Player with microSD Expansion Slot and it stopped working when i unplugged it from the pc before i started to download things but any ways u know how u can lock it well i have to push a button to start it. so i had it on lock and held the button down for like 20 sec's counting slow, then that didnt work so i put it back on lock and held it again for 20 sec's again and it worked!! it turned on then i had to unlock to turn it back on to use it again!!! yeah!!! so give that a try...
Sep 12, 2008 | SanDisk Sansa e250 MP3 Player
My c250 turns on, but not in the way I would like it.
Try a hard RESET by holding the POWER and the MENU for about 15 to 20 seconds. That may reset the player back to the factory settings.
Jan 07, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Not turning on
plug it back in. let it sort itself out.
Dec 29, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Cruzer micro 2.0 GB problem
my sandisk cruzer micro 1Gb flash drive was not working for a month while i was copying 5o nos of photo on it.If i plugged in my device my pc getting hanged and the flash drive was not detected, please give me solution.....
Jun 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Sansa m230 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
