Question about Panasonic CT-32HXC14 32" TV
Your Panasonic TV Problem
Please explain how you fixed it. I was impressed with your 1-day fix! We have the same issue with the same TV.
  • mannysriver Mar 15, 2009
    I also have a problem turning on my TV set with a remote or manually. I tried leaving it unplugged for more than 48 hours and still nothing. I have no idea what the problem is . PLEASE HELP !!!
My tv won't work at all. no power, sound, picture.
Posted on Jul 31, 2008
21 inch Flat CRT Panasonic TV Model 21FJ21CB -it switches off and on automatically?
the tv unit is letting you know there is a electrical issue with the unit.
you need to find out if the unit is worth fixing or buying a new one.
monitors are so cheap now day that it cheaper to buy a new one or a refeburished unit.
Sep 17, 2015 | Panasonic Televison & Video
Panasonic CT-36D31E Television
Seems to me that the technician messed up something on the power board when he repaired the horizontal amp.. I would check for faulty solders, or components first. However, if you do not have prior experience, I would recommend getting a technician to do this, as it is very dangerous to open up a TV.
You could try a hard reset first and see if that helps: Unplug TV from power source and cables for about 2-3 hours and try again...
Oct 30, 2008 | Panasonic CT-36D31 36" TV
Panasonic ct-27g12vsoundnopicture
Direct view or regular TV.
Sound but no picture:
No light on the Screen?
This is rare as if no light usually no sound.
Here is what to look at first (little pun):
In the neck of the picture tube itself (have to remove back and turn set on-----be careful--------just look and do not touch anything inside)
Look in the neck with the set on---you should see 3 faint lights in the neck---the filaments for the tube.
They will not be extremely bright but you should see them; they are supplied 6.3 volts from the set.
If they are not lit it is your problem.
Understand please when I answer a question I never know how much if any skills someone has.
First either check or have someone else see if the filaments are lit.
If they are not---I can explain how to resolve this issue and fix the set.
This is the most likely area for your problem--some sets with this will go dim and then come back up to normal or near normal brightness.
Use the "make a comment button" (tiny) on this page to reply.
Mar 25, 2012 | Panasonic CT-27G13 TV
We have a panasonic tv, model pt-60lc13, bought new in 2003. we use it less than 1 hr per day (last year we watched 2 movies). today, I turned the tv on, the green power light would blink slowly for...
This sounds like a power supply problem, or a vertical issue. The Panasonic sets are one of the best tv's out there and generally worth fixing, but it will need a tv technician to resolve the issues.
Jan 16, 2011 | Panasonic Televison & Video
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
Lines at the top of both my Symphonic tv's
You have a vertical deflection issue on both. Sounds like a bad capacitor. This repair is tricky but not expensive. Have a shop check it for you. Thanks for using fixya.
Feb 28, 2010 | Panasonic CT2722H TV
I turned on the DLPtv it made a weird sound and nothing happened.
Sounds like the High-voltage went out on the TV, probably have to replace TV
Aug 22, 2009 | RCA TruFlat 27F520T 27" TV
Panasonic CT-27D12D turning off on it's own
it sounds like a DRY SOLDER somewherein the PC board where the POWER SUPPLY located , I suggest , if your HANDY with this procedure, Im sure you can get it fix , FIRST lets remove the back cover to get inside the TV ( if TV was recently turn ON , you need to unplug it and wait till the next day to do procedure , cause the picture tube acts like a BIG capacitor reserving electricity,cause we goona need to remove that big RED round rubber plug to the tube ) . to make it short , you need to remove the PC BOARD and look for any dry solder , and resolder it ,that will take care of this problem
Apr 18, 2008 | Panasonic CT-27D11 27" TV
High Pitched Noise, No Picture, Need To unplug to make it stop
It is probably easier to take it somewhere to have it fixed as you will spend hours and still might not fix it correctly.
You need schematics for your TV.
If you really need sources for these parts, you might be able to find them from digikey, mouser or newark electronics.
Look on this link for more repair hints for HOTs
http://www.repairfaq.org/REPAIR/F_monfaqi.html#MONFAQI_006
Mike
Oct 31, 2007 | Panasonic CT-36D31 36" TV
Panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Aug 30, 2006 | Panasonic CT2722H TV
Panasonic CT-32HXC14 32" TV Logo
233 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
