Question about Maytag M6Q10F2A Air Conditioner
Air conditioner does not come !
Think something is wrong with the timer? unit will not start. when it does he compressor will not kick in?
    Sergeant:
    Champion:
  • 417 Answers
Needs regasing or it may have a gas leak
Posted on Jul 03, 2008
The unit either encountered a brown out or a surge which burned up the board for the condenser. It had black marks on the board and the indoor unit was flashing. Replaced the board and the unit is still...
After replacing the burned condenser board, check also the entire condensing unit if still ok ( compressor and fan motor). If the light inside the indoor unit is still flashing, the timer is still not giving signal for the compressor to start. Adjust temperature and wait for 3-5 minutes. It light continue flashing, there is something wrong with the indoor unit control.
Sep 02, 2011 | Sanyo Split System Air Conditioner
Will not cool. Have had freon put in. compressor won't kick on.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 22, 2011 | Frigidaire FAC125P1A Window Air...
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
A/c unit is not blowing cool air. I took it apart and cleaned all the coils, but it still is not cool. There is also a sound like something is trying to kick on but it just kicks right back off.
sounds like the compressor is having trouble starting. this could be the start components or the compressor itself. if the fan is running when you hear the "kicking in" noise it is you compressor, they are generally PSC motors, that require a capacitor to start, the capacitor could be bad, or the compressor may need a start kit added to it, they are available to the public at most appliance parts houses, you will need the model and serial number of the unit to select the proper one.
Jul 30, 2009 | LG LWHD1800HR Wall/Window Air Conditioner
Ammonia smell when Dometic Air Comditioner is on
sounds like you have an old unit and it has a leak , the real old units where filled with ammonia as the gas
Feb 16, 2009 | Dometic Rooftop RV Air Conditioner
I have a york hvac system that is 5 years old. I have the thermostat set at 74 and when it turns on only the fan runs circulating the existing air in the house about 20 percent of the time. The a\c works...
It sounds to me like you have a delay on start timer on the compressor that possibly is starting to fail or someone may have adjusted the time band up on it. I myself would remove it and install a delay on break timer and a 5 minute setting would be ample time.
Hope this helps Ya
Jul 13, 2008 | Heating & Cooling
Maytag M6Q10F2A Air Conditioner Logo
44 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
