Question about GE Profile WPSR3120WWW
GE Washer WPSR3100W0WW roars like a freight train in spin cycle
I have a GE washer Model # WPSR3100W0WW which is roaring like a freight train in the spin cycle. I've been researching this a bit online and have pulled off the front and checked the tub holders on each corner - they appear to be fine. Is there a way to figure out if this is just a bearing or a major clutch/transmission problem? Also what sort of costs are associated with each?
Thank you, thank you, thank you
Dave
  • calnlin Jul 08, 2008
    I have the exact same problem and was told that the cost to repair is more than its worth. New motor & transmission.
  • daveororpha Jul 09, 2008
    What? I just paid the 14.95 fee for tech support here and the tech I talked with said that it sounds like a tube ball bearing for $8 bucks which would, of course, wind up being a total of $150 by the time an appliance repair person would fix it. But what I don't want to do is fix a $8 ball bearing and then also have a bad transmission. Alas alack
  • 1,543 Answers
You would need a transmission (WH38x10002) which comes with a new tub seal, and runs between $150 and $200. Check the back of the owners manual to see if your washer has a five year warranty on the transmission. (newest ones may be only 1 year) They do make a couple special tools which make the repair easier, and an experienced tech can do one in about a half hour, but your first one will take much longer. Motor is most likely just fine.
Posted on Aug 28, 2008
Please help me find what's causing my GE top load washer to sound like a freight train in spin cycle??
First, a huge thanks for including a video of your problem. I wish all answer seekers would do the same. It helps greatly.
The video helps greatly, but is missing many important parts/areas to help fully diagnose. One thing that I noticed, tho it was a "split second" shot, was the wobble in the agitator, which seemed to wobble/vibrate in greater magnitude than the tub. The agitator should sit firmly on the shaft, and not wobble so much. (if a 2 piece agitator, the smaller finned top section is normal to wobble a little bit more tho).
The roaring noise indicates another problem, most likely a worn tub bearing. I'll include a link to a YouTube video that shows replacement of a tub bearing. Also make sure the 4 short upper rubber "shock-dampening straps" (tubular in shape) are not overstretched or broken from age/use. If so, they need replacement.
The general movement of the tub and motor assembly in your video is within the realm of "normal". But is perhaps on the upper limit of normal movement.
Tub Bearing Replacement part WH2X1198 GE Washer Repair
Nov 01, 2014 | GE Washing Machines
Kenmore 90 Series washer, won't spin, just loud roar in spin cycle
This site was very helpful to determine problems I had and they have the repair parts. http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help
Apr 28, 2014 | Kenmore Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 07, 2010 | Washing Machines
Roars when it spin's..but it spins freely? i think its a roller,but how do i get to them ?
If your Neptune front loader washer is roaring in spin cycle you have a bad drum bearing. This repair requires a bearing and seal overhaul. The bearing comes as an assembly with the outer tub. The seal kit usually comes with tub assy. The basket shaft will need to be changed also. This is a time consuming and expensive repair, best done by expert. If washer is still spin drying clothes ok, you might be able to get by for awhile. Repair is usually not cost effective unless you are under a warranty.
Mar 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
ROARING SOUND IN SPINN CYCLE
your bearings are shot your washer needs to be rebuilt it would be cheaper to go buy a new machine
Dec 23, 2008 | Maytag Legacy Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
Roaring sound when spinning, seems like it is going to fly out of pantry lol
Either the tub bearing or lower bearing has failed. Replacing either bearing can be expensive and time consuming. Sorry for the not so good news....
Regards,
reg501
Jun 26, 2008 | Amana NAV8800E Top Load Washer
Washing Machines Logo
939 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
