Question about Dishwashers
Timer switch not moving on and not heating the water
    President:
  • 1,462 Answers
Probably timer not advancing because water not being heated. check element to make sure not open circuit
Posted on Jul 04, 2008
Worcester 28i junior , won't come on, I have no heating but have hot water
First check, in there a room thermostat fitted. If not look at the boiler timer if a circular clock type move the side slider to gentral position and set the timed pins do that when the clock face rotates the pins operate the boiler heating on switch OR if a digital type press the button marked mode to so that on the display there indicator bar moves to the on position.
Dec 11, 2017 | Water Water Heaters
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
Just moved into a new house with old heating system. not sure what some of the switches do? or how to set up heating & hot water timer etc?
Need to know a few things first. What kind of heating to you have? Fuel used to heat? Instructions on setting things up are available online from the manufacturer.
Oct 15, 2014 | Hardware & Accessories
Vaillant boiler clock not working
your timer clock may need to be replaced.
Aug 12, 2017 | Water Heaters
No hot water - timer not moving
If you have a meter carefully check power to timer. If there and there is no power out of timer replace it.
Nov 30, 2017 | Intermatic WH40 - Water Heater Time Switch...
Pump runs 5 minutes and stops
Move the slide switch to ON.
Open following link for recirculation system resources.
http://waterheatertimer.org/Water-heater-recirculation-system.html
The recirculation can work on either the timer or the thermostat using slide switch located next to the timer dial.
First of all, look to see if dial is rotating as time passes.
Next look at position of slide switch. If switch is moved to 'timer,' then the timer controls the on-off function for pump.
Move the pins located on timer dial to control on-off times.
If the switch is moved to ON, then the thermostat controls the pump, and turns on until temperature in pipe reaches 94 or 100 degrees F approximately. I forget exact cutoff temp.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 11, 2010 | Laing Thermotech Autocirc Undersink...
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Dishwasher not completing cycles
Is the water being heated??? When the timer reaches the stage where it will not move forward any further, after 5 minutes or so, open the door & see if the water is heating up. The timer often waits for the water to reach the correct temperature. Temp is measured by the thermostat. If the element tests OK, then it could be the relay that switches the element. The relay is turned on & off by the timer. I would say that if the timer is OK & the element has the correct resistance, then it is is more likely to be the relay. Last resort would be the thermostat, but my money is on the relay.
Jul 31, 2007 | Frigidaire FDB641RA Built-in Dishwasher
Dishwashers Logo
166 people viewed this question
Top Dishwashers Experts
