Problem with a TV
My TV is an LCD TV Samsung LW22N23N.
The problem is following: When the plug is inserted into the socket, the TV's power LED indicator lights up as normal, TV turns itself on automatically, but then the screen blinks once and goes off. It does not respond to anything else. When the plug is removed from the socket and reinserted, the same thing happens. Is it a problem with the power adaptor or not? If not, what could be the problem?
Thank you.
  • lisetteadm Dec 14, 2008
    we have exact the same problem with our tv..
    Sergeant:
    Champion:
  • 417 Answers
SORT CIRCUIT SOMEWHERE THAT'S ALL I KNOW
Posted on Jul 03, 2008
The menu keeps flashing on and off. I have turn the tv off 4 or 5 times but it still keeps flashing the light on the bottom of tv goes blue then red really fast
How old is your TV? This normally indicates a power problem. It could be any of the following: power supply on the TV, faulty power strip, faulty wall outlet, faulty circuit board inside the TV, faulty power cord/plug, bad airflow/clogged vents restricting air movement into the TV (can cause intermittent power faults),bad sensor inside TV. This is not completely inclusive by any means. It does mean that you should have it looked at. Someone knowledgeable/skilled should be able to determine the cause fairly quickly using a multimeter.
Apr 25, 2017 | Televison & Video
Tv turns off and on over and over
Hello, This may seem kinda silly but please check that the power cord is fully seated into the tv's power socket. Just remove the power cord from the TV, and re-insert it back in. Also verify that the other end is fully seated into the wall outlet or extension cord!
Good Luck
Rich Lilja
Dec 20, 2013 | Sony KDL55NX810 55 inch 1080p 120Hz 3D...
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung led tv ua40F6400 power board
If you wish to buy a new power board, contact the authorized service centre for Samsung.
Jun 27, 2013 | Televison & Video
60 inch LG Plasma, did have to push the power button 5 to 7 times to get the TV to power up. Now it will not come on at all
The tv before,the tv power supply board already have problems and was slowly dying,that why it require u to pushes 5 to 7 times for the tv power supply board to be able to sustance and hold power for the tv.Now the tv power supply board it is alot weaker or already dead.That why the tv dose not power on anymore.The tv power supply board that the board where the tv power a/c cord plug into it.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 60PC1D 60 in. Plasma Television
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
