Question about SanDisk Sansa c140 MP3 Player
Sansa c140 The sansa c140 1gb mp3 device displays a message "no space for DB please delete more than 4.0MB" when I start it. I tried to format using WinXP but it couldnt be formatted. I tried the firmware updater from sandisk website. That dint work too. I cannot copy files into the drive from my pc in MSC mode either. There are some space left but I cant add new mp3 files. I tried to delete the files which does delete but when I reconnect the files are still there. I tried to restore factory settings. None of the methods work. Please help me fix my device. I love it because it have very good sound quality. Please help me, Thankyou in advance.
    Problem Solver:
  • 17 Answers
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
Posted on Jul 05, 2008
Sansa clip says i must free 4mb then switches off
You should format the device using windows media player or the device itself..that should fix the problem you are having..remember formatting will delete all the date you have on the device..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Sep 19, 2008 | SanDisk Sansa Clip MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
Sansa C150 No Space for DB. Please free more than 4.0 MB
are you able to format the player while in msc mode?
right-click on it while in my computer and select the format option, make sure your selecting your mp3 as this will delete all the files off the device. It if says failed to format, try doing it thorugh disk management. To get there you can right-click on my computer and select manage from the drop down menu. From here you will see disk management on the left hand side. Then a larger rectangular box with the drive letter that represents your player, you can right click on this and select format.
Or just try a different computer, if its the same everywhere then youll probably have to end up emailing sandisk, stating everything you tried. They will probably ask you to do a couple more things, but if you keep at it, youll end up with an RMA*.
*RMA = Return Merchandice Authorization
Jun 21, 2008 | SanDisk Sansa c150 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
The sansa c140 1gb mp3 device displays a message "no space for DB please delete more than 4.0MB" when I start it. I tried to format using WinXP but it couldnt be formatted. I tried the firmware updater...
If you are trying to format the device thru Windows Media Player, try just thru My Computer. My Computer>Device Name, right click and select format. Otherwise you may need to change the mode on the device. Settings>Mode or USB. Please add to the question, if you need more help. Best of Luck.
Sep 29, 2007 | SanDisk Sansa c140 MP3 Player
My sansa is messed up
It is referring to the "database", or the menus on the device. (i.e. - songs titles, music, artists) It needs at least 6MB of free space on the device to create this. If you freed up what you think is 6MB, it may not be enough. Even though you have a 2GB player, there is only 1.85 of usable space on it. So try deleting some more tracks. If not, format the device and start over. Right click on the device in My Computer and select format. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
Mismatch Format
I have formatted it. No songs available when opened the playlist. But when I start the unit it shows "NoSpaceForDB Please Please Delete More Than4.0M.B". The property shows the "0 Memory is free".
Aug 30, 2007 | SanDisk Sansa c150 MP3 Player
Help me fix my Sansa c140
i had exactly the same problem and than i wrote the guys on www.sandisk.com they had my device replaced.
May 15, 2007 | SanDisk Sansa c140 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
