Question about Electrolux Epic 6500 Vacuum
FB600 Electrophoresis System When I hit the start button it initially kicks on but as sonn as I remove my finger it shuts off. I think it must be a bad relay. Can I order a new relay and get a schematic to help me locate which relay it is? Thanks, ****
    Problem Solver:
  • 7 Answers
Your best bet is to get the schematic and find the proper relay. because that is for sure your problem! I would try contacting the company.
Posted on Sep 22, 2008
Vacuum cleaner does not work
most upright vaccums have a reset button at lower rear area of the vaccum. operates similar to gfi plug reset, push button back in usually with small screwdriver. is your debris bag to full? power brush jammed with debris? hose plugged? this will cause motor to over heat and in turn kick out reset button. always unplug power cord before putting fingers in areas where moving parts are!!
Jan 01, 2012 | Bissell Vacuums
Electrolux vacuum brush not turning problem: was vacuuming and rug got caught auto shut off kicked off power to brush. instead of hitting red button to restart brush I disconnected brush to vacuum some...
under the vacuum, there is a guard. remove the guard , either by 2 screws or by 2 clips. there is a belt under the guard. that is connected to the brush. the belt need to be replaced.
Jan 03, 2011 | Vacuums
My Dyson will not lock into the stand position
- Stand behind the vacuum cleaner
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- WHilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square holse basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 16, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson DC07 will not stand upright. It just lays in the recline position.
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square hole basically)
Jul 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson upright suddenly won't stay in the upright position. It appears that a little rubber piece has fallen out of position.
hole basically)
Apr 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Will not start again.
If the cord sparked, then it is bad and needs replaement. If it sparked at the plug end, then replace the plug.
Feb 23, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Lux 5000
You have a blockage in the hose,
Use broom handle or cane to remove it.
http://dysonmanuals.llc.nu/
Chris..
Dec 24, 2007 | Electrolux Lux 5500 Canister Vacuum
Aerus lux 5500
Hi.
Check & replace any filters that are fitted to machine.
Replace bag with new,
Clear hose of any foriegn items & check floor tool for blockages.
Chris..
Dec 18, 2007 | Electrolux Lux 5500 Canister Vacuum
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
