We have a safe with a combination. We lost the combination to the safe . It is the kind that has a wheel that spins around in a circle with numbers on it.
We are going to get a lock smith to help us find the number to our safe box. It is not a fax machine problem. We lost the number to our safe box. Thank you for your time.
Posted on Jul 07, 2008
Lost combination
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Jul 04, 2013 | Sentry Safe Fire-Safe Personal Safe
Schylling child's safe my son lost his combination
My sons is 34, 43. If that doesn't work, pry a corner of the door slightly open so you can see the lock on the other side of the door. You'll see 2 metal semi circles keepin it locked. Then turn right until the flat part is facing left, then turn the knob left until the 2nd semicircle's flat part faces left and the door should pop open. Hope that made sense.
Apr 20, 2013 | Schylling Combination Steel Safe
S0409 lost combination
Apr 09, 2013 | Sentry FIRE-SAFE Combination Safe DS3431,...
S3470, no keys no combination
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
You will need to use the following link for combination retrievals: http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Aug 28, 2010 | Sentry Fireproof Safe
Brinks fire resistant safe model 5059 instruction manual
Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Apr 30, 2009 | Computers & Internet
Opening problems
Right 3, Left 2, Right 1.
Apr 19, 2009 | Sentry Fireproof Safe
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Nov 16, 2008 | Sentry Fireproof Safe
I can't seem to unlock my safe Sentry 1250.
Also make sure you are executing the combination in the right steps... For mine (a three-number combo), these are the steps that work:
* turn the knob to the LEFT, pass 0 at least THREE times and stop at the first combo number
* turn the knob to the RIGHT, pass 0 ONCE and stop at the second comb number
* turn the knob to the LEFT and go directly to the third combo number (do not pass 0, do not collect $200)
Feb 25, 2008 | Sentry Fireproof Safe
Sentury Fire Proof Safe 1250
Is there any way to crack the safe by feel, ive seen it done before and have some experience in opening locks with pin tumblers, but not wheel tumblers. i can find the notch in the third wheel at around 10-15 but i dont know where to go from there. I would not be using this information for any illegal use, i just need to open my safe on my own, and soon, thank you.
Jan 26, 2008 | Sentry Fireproof Safe
187 people viewed this question
jasbo
jasbo
