Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
My Bissell will not lock in the up-right position
The piece that the Detent Lever locks on is broken and I need a new piece. Everyone keeps sending me a new Detent Lever. What is that piece called and where can I get one
    Problem Solver:
  • 5 Answers
Possibly the slider release is broken and needs replacement.
Posted on Dec 14, 2008
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
How do i put the plastic bagless part back
I have an Bissel Cleanview Helix which I think is similar. The lock'n seal lever has to be in the unlock position first. Place the filter cup in first and then the Dirt container next and hold it in place and move the lock'seal lever to the lock position. I hope that this has helped you.
May 26, 2011 | Bissell 8975 CleanView Bagless Upright...
Brushes won't turn and vacuum will not pick up sprayed cleaner
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Dear tech, I have a 12amp bissel bagless cleaner model# 4220-P the part i need is under the foot lever to lower the vaccum cleaner to sweep. The part is the slide pin that locks the sweeper from...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=805734
Generic problem for all Vacuums
Dear tech, I have a
Posted by yurk on Jul 19, 2008
Dear tech, I have a 12amp Bissell bagless cleaner model# 4220-P the part I need is under the foot lever to lower the vacuum cleaner to sweep. The part is the slide pin that locks the sweeper from lowering. It has a spring attach to it. Can I buy this part Bob Yurkovich
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to order the Bissell part is to check with your local vacuum cleaner dealer in your area or to look @ the Bissell website or to call the Bissell cust serv @ the Bissell factory, and give then the name on the Bissell, Model # and they should be able to send you the part. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 19, 2008 | Vacuums
Foot Pedal Broken
For the handle release, part number is Detent Lever 2030052 Try bissell.com, or call a local repair shop, if they repair Bissell's, then they may have this part in stock. You shouldn't have to take it aprt, there 2 tabs on the release that fit into slots on the base, there move the slots so as to release the tabs.
Jun 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Foot pedal broken
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=629933
Foot pedal broken
Posted by Monte79 on May 28, 2008
I have Bissell Power Steamer Clear view IIII #3105403. I let someone borrow it (mistake #1) and he over extended the foot pedal that angles the upright during use. The pedal is still connected, but the power steamer is locked in the upright position. There is also a bit of dirty water in the bucket, and i cannot empty it because it's basically locked in now. HELP
Sorry you are having a problem with your Bissell, it sounds like he bent the handle release lever and you either need to bend it back or replace it depending on the level of damage to the item. Please feel free to contact the Bissell factory to see the best way to fix the problem, it is not an expensive fix however so contact your local vac dealer or get a referral from the Bissell factory for the nearest Bissell authorized dealer in your area.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
411 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
