Question about LG Flatron 775FT 17" CRT Monitor
Monitor is dark
From Dr.Partha
Monitor of LG My PC remains very dark for about 10-15 minutes after switch-on,then gradually clears.I lodged complain through the toll free number given in the cahmemo. One service-provider attended me but couldnot solve the problem. My phone no.-9434239882.Will you send an expert?
  • LG Master
  • 5,568 Answers
I assume that 'clears' means brightens?
The cathode heater is often supplied with a filtered DC voltage of 6-12 volts.
Often, there is a capacitor on a board plugged directly on the base of the CRT and if this fails, its capacitance becomes unstable and insufficient to adequately filter the voltage and supply clean DC.
In some monitors, the capacitor may be on the main board instead of the base of the CRT.
A technician should locate (not difficult) the CRT heater pins if not marked, and determine where the filter capacitor is located, measure it for capacitance and replace it if needed.
The value is normally many times what is required to clean up the DC but this type of part can (and will) break down chemically and its value will shrink to a very small value while its losses climb.
Eventually, this results in the effect you describe.
Posted on Jul 03, 2008
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
My Complain no. is 101005398 regarding ACER Monitor. After @ 20 days monitor has not been replaced. At Customer Care they ask to visit acersupportonline.com, but we cannot understand what action...
FixYa is not affiliated with Acer nor is FixYa a Acer repair center and therefore we cannot assist you in your complaint.
You need to contact Acer or their Customer Care and lodge your complaint with them.
Oct 29, 2010 | Computers & Internet
My pc monitor is going faded , it clear after 20-30 minute, , when i start it it become faded . nothing is seen on screen . screen is going so bright and text is not understandable , and after 20-30 minute...
I'm affraid that this is not a software issue but a hardware one.
If you're not a tech expert all you can do is check the plugs and cables for damage but I seriously doubt that it would help.
The best thing you can do is either go to a service center (and pay for repairs) or buy a new monitor (and pay for a new monitor)
Sorry and best of luck
Nov 10, 2009 | Samsung SyncMaster 750 (Ivory) 17" CRT...
Screen comes up after 5 Minutes
Ok. this is a solution i gave another person that had a similar problem. hope it works for you.
1. Your images come on the screen after a few minutes yes? that means the cable from the monitor is working. no problem there.
So, when you screen "comes up" does it come up suddenly or does it gradually fade in from completely dark to bright? If it fades in, then the problem may be your monitor. if it comes up suddenly, the problem may either you monitor or you graphics card.
Try hooking up another monitor to the computer. If no problem occurs then the problem was definitely your monitor. If the same problem occurs, then the problem may lie in your graphics card.
If the problem is in your monitor, then you can simply replace it. If the problem is in your G-card, then you can replace that as well (assuming you graphics card is not build in). If it is built in, then you still get a new one (assuming you got an expansion port for it *most computers usually do*).
Tell me if this helps
Oct 04, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Black then gradually disappear in crt mointor
This problem needs a professional service technician,the problem could be on the picture tube/CRT or the ply back.
Sep 13, 2009 | LG Studioworks 775N 17" CRT Monitor
My EMachines T2482 will not power up properly. The fan comes on, but the monitor remains in the sleep mode, and as far as I can tell, no POST is occurring. The ring around the power button remains dark. It...
Did you remove the CMOS battery and move the jumper on the systemboard to clear the CMOS? After a few minutes or so, put the jumper back and power on the machine. If it powers on fine, you can turn it off and put the CMOS battery back in.
Jun 06, 2009 | E-Machines eMachines Desktop PC
Screen is on, but does not appear to be on
The monitor was broken. I returned it to the vendor for replacement. Your tech did not seem to feel it was a monitor problem and only focused on the video card - although I asked him directly regarding his confidence of it being a videio card problem versus being a monitor problem.
I will not use your service again.
Mar 21, 2009 | LG 22" FLATRON LCD Monitor
Problem LG XNOTE 229QA2
Please try and external monitor if the picture is OK then you are having LCD problems. I dont know for you but over in the States here: http://lcdrepair.net They maybe, are able to help you.
Sep 29, 2007 | Computers & Internet
Lg 563n monitor problem
Plz check your monitor's vga cable for ok .I think there is problem in 1,2,3 no pins wires continuity.If it is ok then check components thats are connecting these pin to video amp. ic on crt neck.If they are ok then change video amp. ic with new one.Hope this solution works otherwise i am always ready for help
Sep 10, 2007 | LG Studioworks 563N 15" CRT Monitor
LG Flatron 775FT 17" CRT Monitor Logo
140 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
