Question about ASUS P5E3 Deluxe Motherboard - Intel X38, Socket 775, ATX, Audio, PCI Express 2.0, CrossFire Ready
P5E3 motherboard, wn XP lagging, USB lagging
I have this motherboard and have some lagging problem whit usb, and windows. The most common staff is, that keyboard is miss some buttons.But some other mistic staff also happens. PC reboot, the sound also skip for a moment.
Have quad 9450 in pc.
Do someone have some same issues?
  • 2,351 Answers
Hi csoda,
I have not come across anyone having this issue with the Asus P5E3 deluxe motherboard but have had others with same troubles as you different boards & system configurations.
No issue with Asus & the quad 9450. You can read FAQ’s for you're Asus board at this link. (Look to the left under Related Link).
System lag & system reboots seems more related to software issues but can also include some hardware devices including the CPU overheat. CPU overheat usually shuts down the system not restarts. (Check CPU fan. Clean fan if dusty with clean paint brush & canned air).
In pc repair finding the problem for software is often long & difficult. Suggest you update you're antivirus software. Than run full systems scan. (Just to be safe). You can disable system restarts through system properties/advanced/startup and recovery/settings. Remove the check mark next to automatically restart. If you're lucky windows will display the error for restarting windows. I would suggest format & complete fresh install of windows. All the issues have two things in common. Window & the primary hard disk drive. If you are up to it, you can download the hard disk drive's software tools/utilities & setup software from the manufacture’s web site. Most Mfg's provide software utilities to allow you to create either a bootable floppy disk or bootable CD disk so you can check the drive's stability. The software can check for error's & repair any if found. You also can setup other features that can not be done with windows or the bios. You can set up cluster size & format type just to name a couple. Since windows is still working, suggest you back up to CD (If you have a burner) or to a memory stick, you're personal data. If the Mfg's tools/utilities finds a problem it will fix it & you are sure to loose you're data.
Lastly, there are also windows systems defrag & windows disk cleanup utility. That may help with lag but not with keyboard (try swapping the keyboard). Sound skipping is more related to disk performance or corrupted song.
Good Luck csoda!
Posted on Jul 04, 2008
Hi i have a verbatim usb harddisk whit 1tb and the usb is 2.0 but my laptop can't find the device and my windows is xp sow can jou help me greetings Zicko hoek
If your drive came with any drivers be sure to install them.
Also note that the Store N Go 97538 is a USB 3.0 HDD. You will require a USB 3.0 port in order to use it.
More info here:
Feb 28, 2011 | Verbatim 1TB PRTBL USB 12.5MM-3.0 2.5...
Need high speed usb driver
Unfortunately, being that you are using USB 1.1 ports, the high speed 2.0 devices cannot be used. They look the same, but are different hardwares. Even if you hook up a USB 2.0 hub to the USB 1.1 port, you are still stuck with USB 1.1 speed.
Sorry to break the bad news. Let me know if there are any more questions regarding this issue.
Feb 26, 2010 | Dell Latitude C400 (C400GH0E220LH06) PC...
Hi Running WIN XP (32bit) Have just replaced the Motherboard with an ASUS P5E3 Upon boot up, Windows XP dooes not recognise the USB mouse. The mouse is plugged directly into the MoBO's USB port. I...
Method 1: Initiate recognition of the USB device by using Device Manager----To initiate recognition of the USB device by using Device Manager, follow these steps:---
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Managerwindow opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub---Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:===
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.--
If this method does not resolve the issue, go to method 3--- Method 3: Restart the computer---To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site:----
--- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 02, 2010 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
HP DC5000 SFF and Windows XP SP2 USB PROBLEM
go to bios and verify if USB controller is enabled
Jul 16, 2009 | HP Compaq dc5000 PC Desktop
Asus p5e3 freezes at POST.
Hi David,
Maybe you could buy a new CMOS battery and replace the old one..
Might be worth a try..
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
Usb Rumblepad 2 problems on a asus m2n-mx
Are the drivers for your device Vista compatible?
Head for the manufactuerer's website and get the latest software. There might be bug fixes that will solve your problem.
Apr 03, 2008 | ASUS M2N-MX Motherboard
Portege 3110
i have a bootdisk whit suport a usb , put this disk in floppy and plug this cdrom in usb , next steep install a fresh copy so windows 2000 , evething works fine .
sendme a email and i send for you a copy image disk and sorry a poor english ok !
Mar 25, 2008 | Toshiba Portege 3110CT (P000278510)...
USB port is not working under windows xp sp 2
Usb suffers from electrostatic charges problems. unplug your PC power cable from outlet for 20 mins and plug it back.
Mar 02, 2008 | Soltek SL-75FRN2-L Motherboard
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Open Questions:
See all ASUS P5E3 Deluxe Motherboard - Intel X38, Socket Questions
ASUS P5E3 Deluxe Motherboard - Intel X38, Socket 775, ATX, Audio, PCI Express 2.0, CrossFire Ready Logo
177 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
