When i try to turn on camera i get message pile faible and it turns off. What is that?
I believe that is a "low battery" error. You need to change the battery(ies). Check that your charger is working correctly as well if you are using the rechargeable batteries. (The camera takes 2 AAs, 2 rechargeable AAs (SNB-2312 or SBP-1303) or 1 CR-V3). If new batteries do not help, check the contacts in the battery compartment for corrosion or bent contacts. Often a pencil eraser used gently can remove the first problem. Gently unbend any bent contacts.
After you put in new batteries, you can change your language setup. Press Menu (when not in voice record mode), use the left/right arrows to choose Setup (Ajustage) (the icon reads SET with a crescent in the upper left). Use the up/down to select the third item in the list (Language/Langue) and press the right arrow. Use the up/down arrows to highlight English (Anglais) at the top of the list. Press the OK button. Press Menu twice to get the menu to disappear.
I hope this helps.
(please excuse my spelling, I don't flip back and forth in my mental dictionary well.)
