Twinhead 340S Laptop drivers:
Hi, I have an old Twinhead 340S Laptop running Windows 98SE, 750MHz, 128Mb RAM, 10Gb hard drive, and I need the video drivers, as well as the sound drivers: I've tried every way to find out what video and sound devices are installed, but with no luck: I've used Belarc, and it says video and sound hardware not discovered or installed: Please help..... If I knew what hardware was used inside the laptop, I might know what drivers to look for....Thank you, David.....
    Genius:
  • 2,028 Answers
This is all I could find as far as sound and video for the 340S. SiS630 chipset includes ethernet and sound, and SiS300 graphics. Hope this helps.
Posted on Jul 03, 2008
Need drivers for Twinhead DURABOOK S14Y
The drivers for your product can be found at: http://www.gammatechusa.com/CSD/download.php?model_id=d14ry
Jun 17, 2011 | Twinhead DURABOOK D14RY
Will the Aspire 5100 run Windows 7?
if your laptop meet the requirements of windows 7 it is good>>. it can run the windows 7>>> i will give you the system requirements of windows 7>>>>
  • Processor: 1 GHz 32-bit or 64-bit processor
  • Memory: 1 GB of system memory
  • Hard drive: 16 GB of available disk space
  • Video card: Support for DirectX 9 graphics with 128MB memory (in order to enable Aero theme)
  • Drive: DVD-R/W drive
Dec 14, 2009 | Acer Aspire 5100-3357 Notebook
Touch pad issue
check the control panel and see the setting of the touch pad under the mouse in control panel setting
Sep 12, 2009 | Dell Latitude C600 Pentium III 750MHz,...
I bought the sims 3 and it keeps crashing sayin display driver stopped working how can i update it
Here is the Dell's driver page for your laptop.
Insperon 6400
Select your operating system and the appropriate drivers for you video card.
If you do not know what card you have you can find it by entering devmgmt.msc in the run dialog box and looking under Display Adapters, or you can use an application such as SIW to find the information.
Simply running the .exe file and restarting should update your drivers. If you this does not work or you need more information on how to update your drivers please let me know.
Also, check to make sure that your system meets the minumum requirments for the game if you haven't already done so.
Laptop (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 2 GB of RAM
Jun 12, 2009 | Dell Inspiron 6400 Notebook
Link with pc
hi,
If u want to connect through LAN Cable simply use on cross cable and then u will have to give the IP address to both computers.
Make sure that workgropup is same.
May 28, 2009 | Dell Latitude C600 Pentium III 750MHz,...
Need java for windows 98
I would stongly recommend getting a newer computer as win98 has a very long list of limitations and todays computing requires quite a bit
May 12, 2009 | Dell Latitude C600 Pentium III 750MHz,...
My dell laptop wont do disk check and wont continue on windows what will i do to fix it
You should try to boot it into safe mode and then run a virus scanner you should also be able to run disk check in safe mode. Usually pressing the F12 key during bootup will bring you to the boot menu. You have to watch carefully because the option appears really fast at the beginning of bootup.
Mar 27, 2009 | Dell Latitude C600 Pentium III 750MHz,...
Reg:video card upgradation
Should not be a problem. Install the hardware and then when the system detects it, load only the drivers for an XP from the cd. There are other programs on the cd, but do not load them untill U know the whole system is working properly. U may want to consider adding more ram as faster video requires more ram, suggest 1Gb. and remember that windows is a disk dependant system, the higher percentage of the hard drive U use, the poopier the system runs. Suggest jumping to a 250 Gb harddrive and never worry about it again.
Jun 18, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
HCL 2301 LEAPTOP XP INSTALLATION
DEAR SIR,
MY HCL LAP TOP IS NOT ACCEPTING HDD AS IT DISPLAYING MESSAGE IN FDISK UTILITY NO HDD FOUND. IF I TRY TO INSTALL XP ON THIS LAP TOP IT RUNS INSTALLTION SEGMENT NO.1 AND NEVER SWITCH OVER TO SEGMENT NO.2 AND 3. KINDLY GIVE THE SOLUTION TO THIS PROBLEM.
JAVED AZIZ KHAN
May 20, 2008 | Computers & Internet
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
