Question about Dometic Refrigerators
RV refrigerator repair
Dometic RM3601 AES RV Refrigerator:
The refrigerator lights on gas but as soon as the ignitor quits sparking the burner goes out. (approx 2-3 minutes). The gas failure light comes on. It works normally on 120 VAC. The thermocouple was tested good. The gas flame is nice blue in color and normal height. Thank you for any help you can give. Ken
    Top Expert:
  • Dometic Master
  • 7,206 Answers
Bad flame sensor
Posted on Oct 14, 2017
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 532 Answers
SOURCE: RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
Posted on May 10, 2009
VtToolMan
  • 704 Answers
SOURCE: Gas side of fridge works perfect all day, stops during night!
Sounds like you have some blockage issues and the venturi tube and pilot may need a more complete cleaning. It's possible that the supply pipes have rusted enough on the inside that you're getting small rust particles in the gas and thus into the fridge. You may have to replace the supply lines to resolve this, but...
...rather than 2nd guess what's happening, here's the a link to the diagnostic service manual for your model. You may have to enter in a code to access it once on the website, but this manual will help you troubleshoot your fridge like a pro.
http://gasrefrigeration.net/dom_techdata/7030_7732SM.PDF
Hope this helps and you solve the problem. Best regards!
Posted on Jul 30, 2009
  • 15 Answers
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Posted on Jan 29, 2010
  • 10 Answers
SOURCE: i have a dometic rv fridge. it works on the 120
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
How to operate Dometic RM3601 on gas?
check if clicking check for cobwebs if no clicking bad board
May 10, 2014 | Dometic Refrigerators
Spark ignitor will not quit sparking after burner is iighted.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
Oct 10, 2010 | Dometic RM2652 Refrigerator
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
May 10, 2009 | Dometic RM2652 Refrigerator
Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic RM2620 Refrigerator
Refrigerators Logo
142 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
