Cpu overheat my cpu overheated; what information do i need to be able to replace the fan? and what would be the best type of replacement fan?
    Sergeant:
  • 313 Answers
You would need:
1. Make and Model of computer
2. Processor Name, Speed, and type
To replace the fan you would also have to get some thermal greese to apply to both processor and new fan. Depending on the fan, you might consider asking a local tech to install it for you.
Posted on Jul 03, 2008
Cpu fan wont rotate
CPU fans are notorious for locking up. You can try lubricating it with a WD40 type product but this usually is only a temporary fix. The fan should have some manufacturers information on it. Try a web search for that information and that should lead you to a retailer who can sell you an exact replacement fan.
Jul 26, 2013 | Computers & Internet
Overheat
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
May 10, 2013 | HP Compaq Presario CQ40-330TU
I keep loosing conectivity on my computer. all lights shut off and can not type anything in
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 11, 2012 | Computers & Internet
My computer keeps shutting down after a few minutes. I have replaced the powersupply as well as the cpu fan. I am being told now that it is the system/motherboard. Is that an accurate answer?
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.When you replaced the CPU fan, did you put new thermal heatsink paste on the CPU/heatsink? If not then the CPU can overhest. Your computer fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Mar 21, 2012 | Computers & Internet
Cpu overheats
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 25, 2012 | Gateway GT5012 PC Desktop
Laptop Overheats
Feb 16, 2012 | Computers & Internet
CPU fan failure causes system to aromatically shut down..
Without a proper working cpu fan the cpu will overheat and shut the computer down... if not fry the cpu. You will need to replace the cpu fan and hope the overheating didn't mess up the cpu or something on the motherboard.
Jul 06, 2011 | HP Hewlett Packard HP-COMPAQ DX2450 MT...
My Dell Inspiron 15R fan is not working....the laptop gets overheated due to this & shuts down after 15-20 minutes.The laptop has exceeded its warranty period.I had bought the laptop in May 2010.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
May 28, 2011 | Dell (6F858) Cooling Fan
I changed my cpu fan out, when i started it up it ran 30sec and shut down. So i replaced new mother board without fan., it still shuts down after a few sec. I disconected the 4 pin power source and it will...
From your problem description it sounds like the CPU was overheated (and failed) before you replaced the CPU fan - so the fan replacement was too late. Since the procesor already failed, installing a new motherboard without a fan did not accomplish anything.
The 4 pin power plug provides +12 volts DC to the processor. When you disconnected it, the processor essentially could not run at all and the system is no longer capable of detecting the CPU failure and shutting down the power supply.
You need to install a known good CPU which is the right type and speed for your computer. Unless you are experienced in replacing,CPU's, fans, heat-sinks and applying thermal grease I recommend that you have a PC technician perform these tasks.
If you believe that this information is of value to you please rate me on the FixYa website.
Regards,
Yavacotech
Nov 29, 2010 | Computers & Internet
Fan overheat
Hello there iainmurray_m.
You have a desktop PC with an internal fan that is overheating, correct?
If so, without delay replace the likely failing fan.
If the fan is atop your CPU heatsink assembly, SHUTDOWN PC RIGHT NOW AND REPLACE IT BEFORE YOU FRY YOUR CPU CHIP!
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback.
  • if you have any further questions,
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 06, 2009 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
