Do i have to turn the amp all the way up i use it for djing in clubs using a peavey cs 800 with a mixers or do i turn the mixers all the way up thank you.
As with any power amp. Using the volume control on the power amp can reduce the amount of noise when a signal is absent but at a reduction in headroom. This means that when the signal going into the amp exceeds the headroom your signal will distort. FOr use at low volume levels with a fairly compressed input signal you should have no problem running at less than 100% on the power amp.
Posted on Apr 30, 2009
Fix it.
Posted on Jul 05, 2008
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
Apr 11, 2012 | Peavey Audio Players & Recorders
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Peavey cs-800 amplifier
Believe it or not, these amps have been around since the early 80s and are still available today. Contact a local Peavey dealer or Peavety directly,. These parts are still available.
Dan
Aug 25, 2009 | Peavey Audio Players & Recorders
Peavey 2600 Low input = Complete Cutout
I'm not quite sure of how the two amps are interacting here, so I'd like to request that you describe the entire hookup. Sending a higher signal from the mixer should not be a problem, but something is wrong in the setup (I think). Please update this with a description of how you have the mixer and amps connected to the speakers. Thanks, Dan
Jun 15, 2009 | Peavey PVĀ® 2600 2-Channel Amplifier
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
Plug in Numark mixer & twin CD player to a Peavy CS 1200 x amp. There are diagrams but im lost
simple.numarks outs to peavey's inputs.probably rca's to quarter or rca's to xlr's
Dec 08, 2007 | Audio Players & Recorders
104 people viewed this question
 Grubhead
Grubhead
