Question about Carrier Heating & Cooling
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
  • 40 Answers
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Posted on Jul 03, 2008
Carrier infinity 2-stage heat pump, Error 56 - Temp sense out of Range; and frost forming on heat pump coils although outside temp is 60F
That unit is a very complex machine. The temp sensor out of range issue may be as simple as the sensor being unplugged, or the sensor/outdoor control board needs to be replaced. The "range" it states it an ohm value in the sensor, that the board cannot evaluate properly.
Oct 18, 2017 | Carrier Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
Sensor Error on Thermostat for Carrier Infinity System
Either miswired, or incompatible components, or outdoor thermistor isnt installed or is bad
an easy fix if onsite
Aug 23, 2009 | Heating & Cooling
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
Carrier Programmable Thermostat - E5 Code
Ok what you need to do is call your local service company and have a technician come out and check your Thermostat, its currently not able to read humidity probably due to a power surge
Apr 28, 2009 | Carrier Heating & Cooling
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Apr 01, 2009 | Carrier TSTATHPP 7-Day Programmable...
Heating & Cooling Logo
484 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
