Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 75th anniversary garage opener
Light on back is blinking 5 times the door wont open but the light will come on, do you think it its the logic board. I think it was struck by lighting.
  • 504 Answers
IF THE DOOR MOVES 6-8 INCHES THE PROBLEM IS THE RPM SENSOR IF IT DOESN'T MOVE AT ALL THE CIRCUIT BOARD IS TOAST.
GET A SURGE PROTECTOR FOR THE OPENER - THIS SHOULD SAVE THE BOARD THE NEXT TIME.
HOPE THIS HELPS
Posted on Jun 17, 2010
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
L have a craftman 75th anniversary garage door opener l need the frequency of work to buy a new remote
What color is the learn button?
If the learn button is Red/Orange it's 390Mhz
If the learn button is Purple it's 315Mhz
Feb 20, 2015 | Building Materials
Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
R garage door opener model 139.53640srt -remote car openers wont work suddenly. have to open using the house opener, whose light is blinking
Press and hold for 3 seconds the lock button on the wall control. The light should stop blinking and your remotes should now work.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener model 139.53674SRT2. It was working fine and we opened it and closed it twice today with no problem. The third time we opened it, it would not close. Both led...
The led blinking 5 times is the code for "RPM sensor or motor overload." The motor has an thermal switch which opens when the motor get hot from running too much. This automatically resets itself after about 15 minutes. This problem can also be caused when the door opens too far and the trolley jams against the bolt just in front of the motor unit. To correct this you need to loosen the chain enough to eliminate the tension against the trolley and then run the motor until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
L.E.D lights at back constantly blinking, garage door won't open
If the LED is blinking randomly it is normal. If it is blinking rapidly you have interference from somewhere. To eliminate any interference start unplugging anything electrical and watch the LED. Some things will interfere that you wouldn't even think of like a heater in an aquarium. Check everything especially in the garage.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 horsepower not working
Five flashes indicates possible RPM sensor failure. First try unplugging opener for five minutes and plug back in. If it still does not work replace RPM sensor.
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,186 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
