Hi I have a Sanyo tv model ce27lc3-b...we have noticed on the picture there are brown lines showing through..could you know how to correct this
If the internal degaussing coil is working properly it will remove the coloration after a few ON/OFF cycles. (most sets have a time constant built in, so the set must remain ON for a full minute to allow the degaussing coil current to reach its maximum).
If the coloration really is not caused by an external magnetic field, then the set should be returned to the manufacturers warranty facility or the retailer so the degaussing circuit can be repaired.
Relating to TV
Regards Pauline
Posted on Jul 04, 2008
Sanyo DP58D33 tv. Powers on no picture but sound. Flashlight test shows picture need to know which part to replace none of the parts are called led driver
You need the back light ballast board. Some are separate, while some models incorporate them in the power supply board. Go here to find out what parts you need. TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | Sanyo Televison & Video
I have a sanyo vhs and recorder cords are correct in tv and vhs plays sound but wont show picture on tv tried different cords tried cable cord was working then all of a sudden quit what can i do
vhs either has the picture circuit out or the heads are way too dirty to work. you can clean the heads on these it is pretty easy, if you would like to know how you can let me know.
Nov 05, 2015 | Sanyo Televison & Video
No picture used to have lines at the top
It could be your current problem, but it is not the problem causing the lines.
You can send the main board to us and we can test it and see how it behaves, possibly fix it, but we likely won't be able to take care of those lines.
Feb 24, 2014 | Sanyo DP46848 LCD TV
No picture there used to be lines at the top
It sounds that there is some loose contacts with any cable connectors, or to any solder terminals at the circuit board. It will be best to contact any service technician, or the authorized service center for Sanyo. Gopakumar Gopalan Google
My LCD Sanyo tv won't show picture and the green
Dec 27, 2012 | Televison & Video
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
There is an approximately 3" line of blue light
IS it like the picture is being cut off? You may need to check the connections to your buffer boards and main logic boards.
Apr 05, 2011 | Sanyo DP42746 42 in. Plasma Television
I have a Sanyo and it has a horizontal line in the middle with no picture, but with sound. what could be the problem? I have noticed that if we tap the side or top of the TV, the picture resumes;; but now...
You have a frame collapse, if you had previously been tapping it to come on then it sounds as if there is a dry solder connection most probably on the frame IC or surrounding component. If you are competent with the use of a soldering iron, then remove the back & gain access to the underside (circuit print board) of the TV. Look for an IC that is attached to a heat sink & carefully resolder the pin connections. Look closely at the surrounding solder connections & if any of them look dry then re-solder them also. Without knowing the model of your TV then I can't be more precise as to the specific component location. If you do not want to attempt this then a local repair shop should be able to easily fix it for you.
Jul 29, 2009 | Sanyo DS31520 31" TV
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
Sanyo DS24425 Intermittent Discoloration
It seems like this problem would have to be with the picture tube itself, although I have never run into this symptom in over 30 years of servicing TV's. If the CRT is still in warranty I would get it checked out. Otherwise it probably not be worth repairing. If you end up replacing the set, check out the Toshiba 24" model. I have had good luck with that model in the past.
Feb 11, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
Top Televison & Video Experts
