Question about Plantronics - Bluetooth Headset Plus Base & Headset
NEED PASSWCODE FOR HEADSET - Plantronics - Bluetooth Headset Plus Base & Headset
  • HEATON605 Jul 03, 2008
    thank you so very much!!! =)
  • 405 Answers
Good Day,
Passcode is "0000"
Hope this helps
Posted on Jul 03, 2008
No sound coming through to headset
need to know more. while headset is plugged in try very gently pulling the jackplug out of the socket, if you get sound with the jackplug positions you may have the wrong six
ze plug or the headset may be faulty. try the headset on other devices that function correctly. Also plug another headset into the socket that the headset is currently is plugged into. If another headset functions then the headset must be faulty. It is a matter of experimentation to find what the problem is but you might need a known working headset to carry out the testing procedure.
Good Luck
May 26, 2015 | AUVIO Stereo Wireless Headphones
Headset not working in opti point 500 basic
In order for a headset to work on that phone, you first need to make sure your headset is compatible with it. For example, our headset system:
http://www.aiheadsets.com/lxg-800.htm .
From there you would need to make the necessary switch adjustments on the setup . You are probably going to need a battery operated devise like ours. If you could provide your current headset model, I can help further.
Nov 05, 2012 | Siemens OptiPoint 500 Basic Refurbished
My cardo blue tooth device is not connecting with my nokia mobile phone E71x. pls. guide
Have ever connected the Headset with any other Phone?
If the answer is yes then you need to reset the pairing in the headset device for that u need to follow the user manual. Look for "How to Reset Bluetooth Headset?"
Jul 14, 2011 | Cardo S-640 Bluetooth Headset Wireless...
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
I have an LG Keybo phone and am trying to pair it to a motorola bluetooth headset but it won't connect it. I noticed the version of the headset is 2.1 and the version for bluetooth on my phone is...
You will need the same version of bluetooth and the headset. Version 2.1 is backwards compatible with version 1.2. That being said, your phone will need to have the higher version of bluetooth technology. So therefore your headset will not work with this phone.
Mar 04, 2011 | Motorola Mobility Bluetooth Hands Free...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Blinking green light on microphone, headset not working
The blinking light means headset is muted. Un-mute the headset by pushing the small toggle switch on the back of the headset.
You may need to reset the headset. You can do this by first pressing the mute switch on the back of the headset and then simultaneously pressing the call switch on the side of the headset for about 4-5 seconds.
You will need to pair the headset with the base again.
Mar 13, 2009 | Plantronics CS55 Wireless Headset
MASTER CODE IS NOT WORKING WHICH IS GIVEN BY YOUR COMMUNITY
Hi ,
Enter this Master code your issue should resolve
1201406352
It works..
Raj
Feb 12, 2009 | Nokia 1600 Cellular Phone
Security code on my Nokia 1600
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
Then I’ll give you the Master code to reset your Security code.
"Consciousness: that annoying time between naps."
Apr 05, 2008 | Nokia 1600 Cellular Phone
Jabra c500 headset
Blackberry's need a headset with a 3.5mm plug. You bought the wrong headset for your device
Feb 19, 2008 | Cell Phones
Plantronics - Bluetooth Headset Plus Base & Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
