To play mp3 on your PSP, you'll need
- A big enough memory stick duo. The 32 Mb
that comes with your psp will only fit a few songs. To really make it
practical, i recommend that you try and find 1G memory stick. If you
look hard enough, you'll be able to find one for about 0
- You'll also need a Mini-USB (USB A to USB Mini-B) cable or a memory stick card reader to access your memory stick from your pc.
1. Connect to your memory stick
If you are using memory card reader I
assume you already know how to do this. If you are using USB cable,
simply connect the cable to your PSP and Windows will detect it as a new
drive.
2. Copy your music into the folder named "MUSIC" inside the "PSP" folder.
In the memory stick, there should already
be a folder called "PSP", if there aren't any, you haven't been playing
any games! Inside the PSP folder, find a folder named "MUSIC". If it is
not there, don't worry, simply create a new one.
Now, simply copy your mp3
songs into this "Music" folder and you're done. You can also create
folders inside the "MUSIC" folder and put your songs there.
Mp3 Playback Tips
- To save battery, you can turn of the screen by holding the brightness toggle button for more than 1 second.
- Press the triangle button to view other options such as repeat mode and the built-in help.
my memory cannot be entered,please what can i do?
after switching the memory stick,it says no memory stick inside
when i put my memory stick in my psp it said insert memory stick. my memory stick didnt show up anywhere. i even tried a new memory stick still nothing.
