Question about Toshiba Satellite A55-S1063 Notebook
DVD issue The computer is a 2004. I need to load a disc in, but disc hole is too small. How would I do this then? New to computers. I have program loaded in a desktop..Is there a way/cable to do this. Please advise. Thank you
    Genius:
  • 2,028 Answers
I believe you're looking in the wrong place. The disc drive in a laptop accepts the same size discs as a disc drive in a desktop. There is a small button you push on the disc drive and the drive slides out. On laptops the drive doesn't slide completely out like on desktops, it will pop out about an inch then you will need to pull it out the rest of the way to get the disc inserted.
Posted on Jul 03, 2008
I dont have a boot disc, and pc keeps saying to reboot and select proper boot device please help
Try a new battery charge overnight before doing anything to computer.after overnight charge look on side of computer for a very small hole. Insert a thin needle push in the reset the computer should reboot if it does not have all file take down model and brand go on Internet and order boot disc system for 10.00 when you receive disc load computer will WORK GUARATEED!!!!
Sep 04, 2015 | Computers & Internet
How do I open the dvd tray
is there not a small button on the laptop.
Feb 12, 2015 | Acer Computers & Internet
Cannot eject a CD with the ususual methods. How do I get it out?
Computer CD/DVD drives have a small hole near the eject button. Inser a straightened paper clip in the hole and press firmly. The CD should pop out.
Sep 14, 2012 | Computers & Internet
Disc stuck in dvd drive
If you cannot eject a DVD or CD from the drive, you will find a small hole in the drive cover - Take a paper clip and straighten it, then poke the clip through the hole, then gently but firmly push, and the tray will open.
Nov 06, 2011 | Dell Studio 1555 Laptop Computer 15.6-Inch...
My disks are DVD-RW and want tp use them over gain and don't know how. Also when do I finalise then and what for
For RW discs, you need to reformat them to reuse them. For your laptop, you should see a format option if you right click on the DVD icon when you have the File Explorer open to Computer (My Computer). (This assumes that the computer has a DVD writer.)
Finalizing the disc enables the contents of the disc to be read on other DVD players. (This isn't always an issue. For example, a disc burned with WinXP should be readable for a computer with Windows 7 without finalizing. However, if the disc was burned by a DVD player, the contents will not be accessible on any other units without being finalized.)
If the disc has been finalized, you need to take another step before reformatting the RW disc. Put the disc in the unit that initially finalized it. Then look for an Unfinalize option. Then format the disc again. (I've never used this feature on my computer. It's easily accessed on my DVD recorder in the same section of the submenu as finalizing the disc.)
I hope this helps.
Sep 12, 2011 | Computers & Internet
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Jul 22, 2011 | Computers & Internet
I can not ecject the disc
hi there,
do the cd-driver have a tray or is it a slot where you push the cd in?
First off, Shut the computer down turn it on and then fo to the BIOS. (for most computers it's F2, for some it's Del or F10) to know how to do it on your computer when you turn it on and see the ACER logo check which button needs to be pressed so you can enter the SETUP.
Here's how you do it, From shutdown turn the computer on immediately start tapping the required button (F2, F10, Del etc.)
once in the Bios try pressing the eject button and see if the disc will come out.
If it doesn't:
For CD drives that has a tray: check if there's a small hole that you can punch a paper clip (that's the emergency eject button)
For Slot drives: Grab something that will fit in the slot and would allow you to pull the cd out.
Hope this helps!
Jun 02, 2011 | Acer AOD250-1694 (LU.S690D.056) Netbook
Have inserted a disc. can not open disc tray to remove disc
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 27, 2011 | Computers & Internet
My 13 year old son laptop need be reset like new
There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Dvd ate a disc and stopped working
i cant answer all your questions but to retrieve the dvd you will see a tiny hole on the dvd drive get a paper clip insert it into the hole until you fell pressure then push slightly harder and drive will open do while computer is NOT connected to mains or SWITCHED ON.
hope this helps.
Apr 29, 2010 | Dell Studio 1537 Laptop
Toshiba Satellite A55-S1063 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
