Question about Epson Aculaser C1100 Printer
Toner changing how to rotate toner cartridges
  • joiner Jul 11, 2008
    how to rotate the cartridges?
  • Epson Master
  • 691 Answers
Open the front door, poke a screwdriver into the interlock on the left side. Rotate the carriage as you wish.
You can also rotate to the correct cartridge by using the printer driver and via the control panel on the printer.
Posted on Jul 23, 2008
5 Suggested Answers
SOURCE: changing toner cartridges
Go to reset menu on printer LCD Panel
Hit enter button
Scroll down until you get to the "Change Toner M/C/Y/K" hitting the enter key when you get the appropriate letter.
This will rotate the appropriate cartridge to the opening!
Posted on Jun 30, 2008
SOURCE: how to rotate toners
To rotate the toners:
1 press the down arrow until reset menu appears press the right hand arrow once
2 Scroll through the menu until change toner appears.
3 Toner C appears first continue scrolling until you reach the desired toner eg K for black then.
4 Press the right hand button and the red light will appear on yhe main button.
5 Open front door and change toner.
Works for me after hours of searching. Hope it works for you.
Posted on Jul 11, 2008
  • 49 Answers
SOURCE: Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Posted on Feb 27, 2009
  • 1121 Answers
SOURCE: Need to change yellow print cartridge -- can't go through menus
these syte explain how you can reset problem, http://www.zinetic.co.uk/video/dell3010drum.aspx
Posted on Jan 16, 2010
Testimonial: "Your solution let me know I need to buy a toner kit for the Dell 3010cn printer. The YouTube was particularly helpful for removing the external chip. "
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
Trying to change a black cartridge on a 1650 en model. How do I rotate the cartridges after opening the door?
You can't rotate the toner cartridges manually without potentially damaging the printer. To get the cartridges to rotate, close the door and go through the following sequence:
- Press Menu Select to get to the main menu
- Go to the Print Menu
- Go to the Quality Menu
- Select Replace Toner
- Use the arrows to select Black
- When the display says "Black" press Menu Select
- Press it again, the display should read "Open door and replace black toner"
Now the black toner should be positioned to be replaced, and you should be good to go!
Mar 15, 2011 | Konica Minolta Magicolor 1600W Laser...
HOW DO I FIX THE ERROR 004-332...???
1. Reseat and clean the 4 toner cartridges and verify the orange plastic covers have been removed.
2. Reseat the toner cartridge carousel position. By doing the following:
Lift the handle of the first available toner cartridge or toner cartridge attempting to be installed and remove the toner cartridge.
Close the front cover. Power off the printer. Power on the printer.
An LCD message Insert <toner color> Toner appears. Open the front cover. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place. Close the front cover. The toner cartridge carousel rotates to the correct toner position.
3. Verify the developer rotor frame is not bent. If it is bent then the printer should be replaced, it would not be cost effective to replace the frame.
4. If it is not bent. Open the front door, try to rotate the carosel. It should NOT rotate. If the rotation is rigid and feels broken, then the printer should be replaced. If it rotates smoothly, the developer latch should be replaced. If the carosel does not rotate but still gives the error the rotor control board should be replaced.
Jul 16, 2010 | Dell 3010cn Laser Printer
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Jan 12, 2010 | Konica Minolta Magicolor 2450 Printer
How do i manually rotate cartridge carosel
You don't want to rotate the toner cartridges, you need to get a new Drum Cartridge assembly.
When you get that, it will have detailed directions, but you'll end up opening the top of the printer and pulling the drum straight up.
This is a different component than a toner cartridge. The toner carts are the supply of new toner. The drum cart collects excess toner during the printing process, and when it's full you need to get a new (empty) one.
If you connect to your printer's web interface it will have a link for "order supplies" that will take you right to the dell.com page for it.
Post a comment back if you need me to get the URL, and I'll grab it from my printer when I get home tonight.
Sep 02, 2009 | Dell 3010cn Laser Printer
Rotating toner cartridges to change
Every time you open and closes the door cover the toners rotate,open and close it untill she can see the black cartridge.
Apr 08, 2009 | Canon Office Equipment & Supplies
How do I change black toner? Blue is accessible but how do I get it to rotate?
I have opened and closed the front door a number of times so that the cartridges rotate to different positions. It's trial and error until the right color is in the position to be changed.
Aug 12, 2008 | Minolta magicolor 2300W Laser Printer
How to rotate toners
Jul 03, 2008 | Epson Aculaser C1100 Printer
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
How to change cartridge in magicolor 2500W?
If one of the cartridges needs to be changed, the printer will recognize this and it will automatically rotate that cartridge to the front of the printer.
Open the panel and follow the instructions that are shown on a sticker on the inside of the access panel. Removing the cartridges is not difficult. They do have a slight groove near the top that acts as a handle. You may have to rotate the cartridge up as you lift it in order to get it to come out. DO NOT FORCE IT. Once again, please consult the sticker on the inside of the access panel for details on cartridge replacement.
If you need to replace more than one cartridge, press the rotate button to rotate the cartridges to the one that needs replacing and repeat the process.
DO NOT FORGET TO TAKE THE SEALING STRIP OUT OF THE NEW TONER CARTRIDGE BEFORE PUTTING IT IN AS THIS TAB CAN AND MOST LIKELY WILL DAMAGE THE PRINTER. (I've seen it happen.)
After you have replaced the toner cartridges properly, the printer should rotate the drum a few times to prime the cartridges. This is normal. You should see a readout on the LCD screen of the toner levels. (You may have to press a few buttons to see the status on them.)
If you need toner cartridges, head to your nearest office supply store such as Staples or Office Depot for replacements. (Staples will price match other stores if you give them proof of the other store's price.) When I last worked with this machine, the cartridges were still kind of expensive...but worth it for the quality that this machine gives you.
Good luck. :)
Cyryl
Nov 09, 2007 | Konica Minolta magicolor 2500W Laser...
Epson Aculaser C1100 Printer Logo
200 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
