Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
WD3200ME-01 Passport size diskspace problem
Hi Geeks,
I am using a 320 GB WD Passport HD with Dell Latitude D620. All is ok except diskspace problem. When i look free diskspce in HD, it says 212 GB free. I have VPC image of Microsoft CRM just a little more than 10 GB which wish to copy to passport, when i try copy that it says Not enough diskspace and prompts me to run a disk cleanup on passport. I donot wish to move in chunks by doing any RAR packages, because i already got this VPC in form of RAR packages, and when i tried to build VPC file on passport directly that also fails because of diskspace. If somebody could somebody help, that would be GR88888888888.
FYI, i have single partition primary C: drive with 1.1 GB freespace only
ciao
  • Anonymous Aug 13, 2008
    xp no detecte usb Western Digital 320GB
To format the drive to allow files larger then 4GB: Open up My Computer, Right click on the Western Digital Drive. Select Format from the list. Under file System, select NTFS. Under format options Check Quick Format. Click Start to format.
Warning! Formatting will delete all data and files on the drive. Make sure to transfer all your files to another drive before preforming a format!
Posted on Feb 23, 2009
Hi Mr
am using a 320 GB WD Passport HD with Dell Vostro 1510. My drive(WD320) is slow speed.
copy 700 MB in to my WD320 in 20 minute..it have slow speed.
what can i do to improve the speed ?
Posted on Sep 24, 2008
    Problem Solver:
  • 7 Answers
Yea um for this problem it mite help if you do a disk cleanup you might have a lot of **** that is taking up wanted space, if you do a disk cleanup this wont get rid of your files it will just clean up things that are on there that shouldn't be there and maybe if you do a virus check on the HDD it might help to
From the best man
Posted on Jul 25, 2008
Actually its because its formatted to fat32 and you can not put files on bigger than 4 gb. so annoying. i have the same drive that i do not know how to format
Posted on Feb 09, 2009
Trying to add on a wd passport hd thru usb port...plugged in on both ends, and drive sitting there making a clicking noise
sounds like the drive went bad have also try a different usb port make sure you are using one directly connected to the laptop/pc not thru a usb hub
Mar 27, 2011 | Western Digital My Passport Essential 320...
Dell Latitude D620 - push the power button and the power light stays on for about 5 sec, then black. No disk activity or any other lights during this time. It is not HD, as I can put this HD in another...
1.Remove the battery and insert the A/C main adaptor,then ON the Laptop.
2.Remove and Insert the RAM again properly(Cheak with another Good conditioned RAM)
3.Remove the CMOS battery and then repace it again.
4.Remove all drives like hard disc,dvd drive and etc.then ON the Laptop.
All the Best....
Jun 21, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell Latitude D620 When I open my laptop the screen will not come back on. I have to turn it off and turn it back on to get the screen to work.
Sounds like it's going into a sleep/standby mode. Check your manual for the correct key/key sequence to restore it to full operation.
Aug 21, 2009 | CMS PRODUCTS 250GB NB HD SATA-DELL...
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
Need help with western digital wd3200me passport
if it came with a driver disk or an install disk then try running that before hooking up your harddrive
Jun 01, 2009 | Western Digital Elements powered by WD 320...
Ibm t43, xp pro won't recognize my WD 320 passport
Well, that IBM is from 2004, the usb port and drivers is to old for the WD 320 who requries USB 2.0. Thats why your IBM dosent recognize it, your IBM getting wrong signal from the WD thrue the old usb port.
I dont think you gona make those items to work properly togher M8, sorry
Nic
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
4,079 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
