Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher and paykel dishwasher
Flashing f1 light with spanner underneath
  • 413 Answers
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Posted on Jul 04, 2008
Cyle starts to beep before end ofwash
Posted on Nov 29, 2009
2 Suggested Answers
  • 30 Answers
SOURCE: I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
F1 fault means the flood switch on the base of the dishwashers has been activated.You would need to ring someone who repairs dishdraws.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
Posted on Aug 27, 2008
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer keeps blinking with a spanner and F1 function
F1 is a flood error. Below is a link to a video that you can download that shows you how to repair your dishwasher.
Solution
Good Luck
Feb 25, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 flashing with a spanner showing
Hi..
F1 code indicates a leak,you will find the water under bottom drawer.Might be the lid probably not sealing well. You have to seal it well properly to fix this error in your dishwasher.
Thank u !!
Jun 17, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
The unit flashes F1 with a spanner sign showing on both drawers
Refer your problem with fisher and paykel DD603 dishwasher. Please clarify how are you able to assess the motor is driving in top gear. Which lights are flashing?
Is this problem in both drawers or just one?
May 30, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Lights come on with f1 spanner sign flashing and bleeping
There is a leak causing the bottom housing wet so the floor sensor triggers. Dry out the bottom housing F1 will be disappear. However if the leak is not fix, the sam problem will happen again. The leak is from improperly being sealed between the top lid down against the top edge of the tube during operating.
May 07, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
HI my fiser and paykel dishwasher is flashing f1 and is showing a spanner whay does this mean
The F1 error means a flood switch has been activated in the drawer. The spanner means you need to call a technician.
The possible causes are that the solenoid that controls the water inlet does not shut off or the sensor that detects the water level is not working. Also it is possible the water pressure is not optimum for the setting on your unit.
Nov 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
793 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
